Prove Holomorphic on C: Continuity and Differentiability
  • Thread starter Thread starter fauboca
The discussion revolves around proving that a function \( f : \mathbb{C} \to \mathbb{C} \), which is continuous everywhere and holomorphic except on the interval [2, 5] on the real axis, must be holomorphic on all of \( \mathbb{C} \). Participants explore the implications of continuity and the conditions under which holomorphicity can be extended to the problematic interval.
  • Some participants suggest using Morera's theorem as a potential approach. Others express uncertainty about this theorem and seek alternative methods. There are discussions about finding a holomorphic function \( g \) that agrees with \( f \) outside the interval [2, 5] and questions about how to define \( g \) on that interval. The concept of the Integral Transform Theorem is introduced, with participants questioning how to adapt it to show agreement between \( f \) and \( g \) within the specified region.
The discussion is ongoing, with participants exploring various approaches and questioning the validity of their reasoning. Some guidance has been offered regarding the use of Morera's theorem and the Integral Transform Theorem, but there is no explicit consensus on the best method to prove the holomorphicity of \( f \) on the interval [2, 5].
Participants note the challenge of proving holomorphicity on the interval [2, 5] given that \( f \) is not known to be holomorphic there. The discussion also highlights the need for a careful definition of the region of integration and the implications of continuity in the context of complex analysis.
  • #31
morphism said:
Yes, something like that would work.
So I am trying to use Morera's Theorem:
Let U be an open set in C and let f be continuous on U. Assume that the integral of f along the boundary of every closed rectangle in U is 0. Then f is holomorphic.
So let [itex]U = \mathbb{C} - [2,5][/itex] Let R be rectangles in U which are parallel to the coordinate axes. So [itex]\int_{\partial R}f=0[/itex].
Now how can I use this?
  • #32
By the way, "holomorphic at every point" doesn't make sense- "holomorphic" is not a point property. You may mean "analytic at every point". "Holomorphic" means "analytic at every point in the complex plane".
  • #33
I have this proof for finite points but how would I modify it for infinite many points between [2,5]?
Assume [itex]q(z)[/itex] is any function that is holomorphic on a disc U except at a finite number of points [itex]\xi_1,\ldots, \xi_n\in U[/itex], and assume [itex]\lim_{z\to\xi_j}(z-\xi_j)q(z)=0[/itex] for [itex]1\leq j\leq n[/itex]. Let [itex]U'=U-\{\xi_1,\ldots\xi_n\}[/itex]. Then q is holomorphic on U'.
Note [itex]F(z)=q(z)-f'(a)[/itex] so [itex]q(z)=\frac{f(z)-f(a)}{z-a}[/itex]
Step 1 is the Cauchy-Goursat argument:
[itex]\int_{\partial R}q(z)dz=0[/itex] for all rectangles R in U such that [itex]\xi_j\notin\partial R[/itex] for j.
proof:
Let R be a rectangle with the boundary of R in U'. First subdivide R into sub-rectangles so that each sub-rectangle has at most one [itex]\xi_j[/itex] inside it. By Cauchy-Goursat, [itex]\int_{\partial R}=\sum_i\int_{\partial R_i}[/itex]. So it suffices to show [itex]\int_{\partial R}q=0[/itex] if R contains at most one [itex]\xi_j[/itex].
If R contains no [itex]\xi_j[/itex], then we are done by Cauchy-Goursat. Assume [itex]\xi=\xi_j[/itex] is inside R. Let [itex]\epsilon>0[/itex] be given. Put [itex]\xi[/itex] in a square of size x at the center of this where x is chosen small enough so that [itex]|(z-\xi)q(z)|<\epsilon[/itex] for z in and on this square. Subdivide this rectangle so the square which is x by x is its own rectangle around [itex]\xi[/itex]. As before, the integrals of the sub-rectangles that don't contain [itex]\xi[/itex] are 0. So [itex]\int_{\partial R}q=\int_{\text{square with xi}}q[/itex].
\left|\int_{\text{square with xi}}q\right|\leq \underbrace{||q||_{\text{square with xi}}}_{\frac{\epsilon}{\min\{|z-\xi|\}}}\times \underbrace{(\text{length of square with xi}}_{4x}\leq\frac{\epsilon}{x/2}4x=8\epsilon
So [itex]\left|\int_{\text{square with xi}}q\right|=0[/itex].
Step 2 is to use step one to create a primitive for q on all of U.
Define [itex]g(a)=\int_{z_0}^{z_1}q(z)dz[/itex] where the path is from [itex]z_0[/itex] horizontal and then vertical. So [itex]g(a)[/itex] is well-defined. If a point is not unreachable, then [itex]\lim_{h\to 0}\frac{g(a+h)-g(a)}{h}=q(a)[/itex] by exactly the same means as before. Unreachable are the points vertical above [itex]\xi[/itex].
When computing [itex]\frac{g(a+h)-g(a)}{h}[/itex], only consider h in C with [itex]|h|<\frac{\delta}{2}[/itex]. The path for computing g(a+h) also misses [itex]\xi[/itex]. Then for these h [itex]g(a+h)-g(a)=\int_a^{a+h}q[/itex] so the same reason as before show [itex]\frac{g(a+h)-g(a)}{h}-g(a)\to 0[/itex] as [itex]h\to 0[/itex].
To handle all the bad exception.
Pick [itex]\epsilon\geq 0[/itex] such that the point [itex]z_1=z_0+\epsilon(1+i)[/itex] is not on any of the same vertical or horizontal lines as any [itex]\xi_j[/itex]. Of course epsilon is really small compared to the radius of U.
Define [itex]g_1(a)=\int_{z_1}^aq(z)dz[/itex]. This defines a primitive for q(z) on all of the disc except on the unreachable regions.
Define [itex]g_2(a)=\int_{z_1}^aq(z)dz[/itex] but this time move vertical and then horizontal. So [itex]g_2(a)[/itex] is also a primitive for q on U except at the its unreachable points (but g_1 reaches those points and vice versa). On the overlap, [itex]g_1[/itex] and [itex]g_2[/itex] are primitives for the same q. They differ only by a constant. But [itex]g_1(z_1)=0=g_2(z_1)[/itex] so [itex]g_1=g_2[/itex] on the overlap. For a small enough epsilon,
g(z)=\begin{cases}g_1(z)\\g_2(z)\end{cases}
$$ is defined on all of U' and is a primitive for q.
How do I extend this to my problem?
  • #34
Not true; what you're thinking of is "entire".
re: fauboca
Here's what you do. Let ##\gamma## be a closed curve in C. If ##\gamma## doesn't contain any point of [2,5] in its interior, then ##\int_\gamma f =0## since f is holomorphic away from [2,5]. So now suppose that ##\gamma## contains points of [2,5] in its interior. For the sake of illustration, suppose that ##\gamma## is a square with vertices (3,0), (3,1), (4,1) and (4,0). Cut the square horizontally into two rectangles of length 1-ε and ε, so that the smaller rectangle has its base on [3,4]. This breaks up your contour into two contours, and the integral of f over one of them is zero. Now use a limit argument.
The general case is similar.
  • #35
re: fauboca
Shouldn't the square contain the interval? So it would be (1.9,-.1), (1.9, .1), (5.1,-.1),(5.1,.1)?
  • #36
Let ##\gamma## be a closed curve in ##\mathbb{C}##. If ##\gamma## doesn't contain any point from [2,5] in its interior, then ##\int_{\gamma}f=0## since f is holomorphic away from [2,5]. Suppose that ##\gamma## contains [2,5] in its interior. Let R be a rectangle oriented with the coordinate axes in ##\gamma## such that [2,5] is in R such that ##[2,5]\notin\partial R##. Divide the rectangle into two sub rectangles of length ##1-\epsilon## and ##\epsilon## such that [2,5] is contained in one the sub rectangles. WLOG suppose [2,5] is the rectangle of length ##\epsilon##. Then the over f of the rectangle of length ##1-\epsilon## is zero.
I am not sure how you mean to use the limit argument.
  • · Replies 16 ·
  • · Replies 0 ·
