Calculating Fourier Coefficients for an Odd, Periodic Function
The discussion revolves around calculating Fourier coefficients for an odd, periodic function defined on a specified interval. The function is given as f(t) = -5.5 + 22*t² for -0.5 ≤ t < 0, and participants are tasked with finding the coefficients b_n and specifically b_5.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the integration process for finding Fourier coefficients, questioning the bounds of the integral and the definition of the function over its full period. There is exploration of the implications of the function being odd and periodic, particularly in defining f(t) for the interval 0 < t < 0.5.
Several participants have provided insights into the integration process and the properties of odd functions. There is recognition of the need to correctly define the function over its entire period, and some participants have clarified their understanding of the integration bounds and the role of sine and cosine terms in the Fourier series.
Participants express confusion regarding the definition of the function outside the specified interval and the implications of its oddness. There is an acknowledgment that the function's periodicity affects how it is expressed across different intervals.
TW Cantor
f(t) is an odd, periodic function with period 1 and:
f(t) = -5.5 + 22*t2 for -0.5 ≤ t < 0
i) find the Fourier coefficient bn
ii) find the Fourier coefficient b5
bn = (2/T) * ∫ f(t) *sin((2*n*∏*t)/T) dt between T/2 and -T/2
sin(n*∏) = 0 for all values of n
cos(n*∏) = 1 for even values of n
cos(n*∏) = -1 for odd values of n
by integrating f(t)*sin((2*n*∏*t)/T) with respect to t i get:
-(11*sin(n*∏) - 11*n*∏*cos(n*∏))/(n^3 * ∏^3)
replacing the sin(n*∏) with 0 i get:
11*cos(n*∏))/(n^2 * ∏^2)
so this should be the solution to the first part of the question but when i put n into the equation as 5, i get the wrong answer. can anyone see where I've gone wrong?
Can you show your intermediate steps when performing the integral?
In particular, I want to see what the bounds of the integral were and what expression you used for f(t).
Note that your function is only partly defined by this equation:
[itex]f(t) = -5.5 + 22t^2[/itex] for [itex]-0.5 \leq t < 0[/itex]
This defines it on an interval of length 0.5. But the period is 1. So what is an equation for the function for the interval [itex]0 < t < 0.5[/itex]? (You need to use the fact that the function is odd.)
P.S. It won't make any difference when integrating, but what does the oddness of the function imply that f(0) must be?
well I am not really sure what to use as the bounds for the integral... i got confused when it said the period was 1 but the function is only true between -0.5 < t < 0. i know since its odd its asymettric about the vertical axis and since its periodic it might have something to do with that? i could use the equation f(-t) = -f(t) maybe?
Yes, f(-t) = -f(t) is the defining characteristic of an odd function. Try using that to define what f(t) must be for 0 < t < 0.5.
so for 0 < t < 0.5, f(t) = 5.5 - 22*t^2 ?
then do i add the integral of:
f(t)*cos((2*pi*n*t)/T) dt between -0.5 < t < 0
and -f(t)*cos((2*pi*n*t)/T) dt between 0 < t < 0.5
because won't that just equal zero?
how would you integrate for this problem?
You use the half range formulas for the coefficients. Since f(t) is odd you know an = 0 for all n. The half range formula for ##b_n## for a function of period ##2p##, which should be in your text, is$$
b_n =\frac 2 p\int_0^p f(t)\sin(\frac{n\pi t}{p})\,dt$$
Yes, that's right. The cosine terms are all even, and their coefficients will all be zero for an odd function.
What about the sine terms?
ahh! I've been using sin instead of cos! i can't believe i did that.
so I've integrated
2/T ∫ f(t)*sin(n*π*t/T) dt between 0.5 and 0
and i get:
(22*cos(pi*n) - 11*n^2 *pi^2 + 22*n*pi*sin(n*pi) -22)/(2*(n^3 * pi^3))
since I've integrated for only half the period and between 0 < t < 0.5 i have to multiply by -2 to get it into the full period and between -0.5 < t < 0 right? and then i can replace sin(n*pi) and cos(n*pi)?
so I've integrated
and i get:
I didn't check whether you calculated the integral correctly, but your method looks correct now.
yeah I am getting the right answer now :-) thanks for your help!
  • · Replies 16 ·
