Effective angular diameter of the sun for this experiment
This discussion focuses on calculating the effective angular diameter of the Sun using a radio interferometer. The interferometer's azimuthal rotation creates a curved path rather than a straight line across the Sun, leading to discrepancies in angular diameter measurements. The relationship between the curved line's length and the straight line's length is influenced by the Sun's latitude, denoted as θ. The relevant equation derived from spherical trigonometry is: d φ = cos(θ) arccos((cos(d) - sin²(θ)) / cos²(θ)).
  • Understanding of radio interferometry techniques
  • Basic knowledge of spherical trigonometry
  • Familiarity with angular measurements in astronomy
  • Ability to interpret interference patterns from optical systems
  • Research the spherical law of cosines in detail
  • Explore advanced concepts in radio interferometry
  • Study the effects of latitude on astronomical measurements
  • Learn about angular diameter calculations in astrophysics
Astronomers, physicists, and engineers involved in radio astronomy and interferometry, as well as students studying spherical trigonometry and angular measurements in celestial contexts.
omoplata
Hi,
We are using a radio interferometer to measure the angular diameter of the Sun.
An in depth description of how this is done is not relevant to solve the immediate problem I have. But briefly, we rotate the interferometer in azimuth so that the direction it's looking at traverses across the center of the Sun. We take readings of an interference pattern from two mirrors off to the sides during this traverse. Then we use this pattern to find out the angular diameter of the Sun that we saw.
My problem is that the interferometer rotates in azimuth around an axis that is perpendicular to the surface of the Earth, but the Sun is up at some latitude. So the interferometer doesn't trace a straight line diameter across the Sun. It traces an arc. The length of this arc is going to be the effective angular diameter that we finally obtain.
This is described in the attached diagram. The real angular diameter of the Sun is the length of the straight line. But the value for the angular diameter that we actually obtain is the length of the curved line. That curved line is the path the interferometer actually traverses.
I want to find a relationship between the length of the curved line, the length of the straight line, and the latitude of the Sun, so I can find the real angular diameter of the Sun from the value that I obtained.
Could someone please suggest a way I can do this? I think it has to do with spherical trigonometry, but I don't know where to start. I don't want to go through a whole textbook of Spherical Trigonometry just to solve this. What I need is a relevant equation.
Thanks.
Sorry, that diagram is wrong. Attached is a better diagram.
OK, I found an expression for the effective angular diameter of the first diagram (but not for the second one yet) using the spherical law of cosines.
If the latitude of the sun is [itex]\theta[/itex], and the actual angular diameter of the sun ( straight line ) is [itex]d[/itex], the effective angular diameter ( curved line ) as shown in the first diagram ( when the direction the interferometer is pointing towards doesn't go through the center of the sun ) is,
[tex]d \phi = \cos (\theta) \arccos \left( \frac{\cos( d ) - \sin^2 ( \theta )}{\cos^2 ( \theta )} \right)[/tex]
  • · Replies 36 ·
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 32 ·
  • · Replies 19 ·
