What Is the Boundary of a Product Manifold?
The discussion revolves around the boundary of the product of two oriented manifolds with boundary, specifically addressing the mathematical formulation and implications of the boundary operator on product manifolds. Participants explore theoretical aspects, proofs, and examples related to this topic.
  • Some participants propose that the boundary of the product of two oriented manifolds A and B can be expressed as ∂(A×B)=∂A×B + (-1)^n A×∂B.
  • Others argue that orientation is only one aspect of the boundary question, raising further inquiries about the expression ∂(A×B)=(∂A×B) ∪ (A×∂B).
  • A participant suggests a proof strategy involving neighborhoods of points in the boundary, considering cases where points are or are not boundary points.
  • Another participant challenges the diffeomorphism claim regarding mappings between different spaces, emphasizing the topological nature of boundaries.
  • There is discussion about the implications of the proof for reverse inclusions and whether certain points belong to the boundary based on neighborhood considerations.
  • Concerns are raised about the nature of mappings and differentiability, particularly at boundary points.
  • A participant introduces the idea that the product of two manifolds with boundary may result in a manifold with corners, using the example of the product of closed intervals.
Participants express differing views on the formulation of the boundary of product manifolds, with no consensus reached on the correctness of the proposed expressions or the implications of the proofs discussed. Multiple competing views remain regarding the nature of boundaries in this context.
Some arguments depend on specific definitions of boundaries and differentiability, and there are unresolved mathematical steps in the proofs presented. The discussion also touches on the concept of manifolds with corners, which adds complexity to the topic.
mma
Is it true, that if [itex]A[/itex] and [itex]B[/itex] are oriented manifolds with boundary, having dimensions [itex]n[/itex] and [itex]m[/itex] respectivelly, then the boundary of [itex]A\times B[/itex] is
[itex]\partial(A\times B)=\partial A\times B + (-1)^n A\times \partial B[/itex]?
If not, then what can we say about the boundary of product manifolds? Could someone recommend a textbook or a lecture notes that discusses this?
Yes, that's how one typically orients the boundary of AxB.
Okay, but orientation is only one aspect of my question. I'm also curious that why is
[itex]\partial(A\times B)=(\partial A\times B) \cup (A\times \partial B)[/itex]
This should not be hard to prove directly: Assume dimA=m, dimB=n. Take a point (a,b) in dA x B. Two cases:
i) b is not a boundary point
ii) b is a boundary point
In case i), a nbhd of (a,b) is of the form Rm-1 x R+ x Rn ≈ Rm+n-1 x R+. Hence (a,b) is in d(AxB).
In case (ii), a nbhd of (a,b) is of the form Rm-1 x R+ x Rn-1 x R+. You just have to convince yourself now that R+ x R+ ≈ R x R+ to see that the above nbhd is just Rm+n-1 x R+ again. Hence (a,b) is in d(AxB) in this case also.
Etc.
I think I can:
let's [itex]\psi_1: (R_+\backslash\{0\})\times [0,\pi] \to (R\times R_+)\backslash\{(0,0)\}[/itex]:[itex](r,\varphi)\mapsto (\cos\varphi,\sin\varphi)[/itex],
[itex]\psi_2: R^2\to R^2: (r,\varphi)\mapsto (r,2\varphi)[/itex],
then the mapping from [itex]R_+\times R_+[/itex] to [itex]R\times R_+[/itex] that leaves (0,0) fixed and the other points maps to [itex]\psi_1\circ\psi_2\circ\psi_1^{-1}[/itex] is a diffeomorphism from [itex]R_+\times R_+[/itex] to [itex]R\times R_+[/itex]
Your proof proves only that [itex]\partial(A\times B)\supseteq (\partial A\times B)\cup(A\times\partial B)[/itex], but I think that the reverse direction goes similarly. We can prove with your method that if (a,b) is not in the RHS set,then it also isn't in the LHS set. So you thought?
Latex is not showing up, but whatever your map is, I doubt it is a diffeomorphism. Because any homeomorphism F: R+ x R -- R+ x R+ must send boundary to boundary and hence it is not differentiable at F-1(0), where 0 is the "corner point" of R+ x R+.
What I meant by "R+ x R+ ≈ R x R+" was only a homeomorphism... because the boundary of a manifold, after all, is a topological concept.
So far, the argument I gave shows
[itex](\partial A\times B) \subset \partial(A\times B)[/itex]
But it goes without saying that we can get
[itex](\partial B\times A) \subset \partial(A\times B)[/itex]
in the same way. Hence we have so far
[itex]\partial A\times B + (-1)^n A\times \partial B \subset \partial(A\times B)[/itex]
For the reverse inclusion, pick (a,b) in [itex]\partial(A\times B)[/itex]. Then it has a nbhd of the form R+ x Rm+n-1. Find out which of a or b has one of its coordinates in R+. If it is a, then (a,b) is in dA x B. It if is b, then (a,b) is in A x dB.
Dear Quasar987, I greatly enjoy your concise and expressive explanations, they are really lucid, thank you for them.
Also thank you for your remark, that my map isn't a diffeomorphism. Really, as far as I see, however it is differentiable, it's inverse isn't at (0,0). (by the way, is it really a good definition for a bijective map to be smooth, that is sends every smooth curve into a smooth curve?)
Of course I screwed up my formula, I wanted to write [itex](r \cos\varphi, r \sin \varphi)[/itex] instead of [itex](\cos\varphi, \sin \varphi)[/itex], sorry. So, my map simply bends the y+ half axis to the x- half axis, and stretches the area between it and the x+ axis.
And one more note. I understand your proof for the reverse inclusion and I like it, but I'd also like to know if my original thought was correct or not. I imagined an indirect proof, that is, reversing the direction of the inclusion sign an also reversing the statements. If (a,b) is not in [itex](\partial A\times B) \cup (A\times \partial B)[/itex], then it has a whole nbhd inside [itex]A\times B[/itex], that is it isn't in [itex]\partial(A\times B)[/itex]. Is it correct so?
I am touched by your words of thanks mma. I also enjoy discussing with you :)
At the time I wrote my previous post, I could not see the latex code of your post, so I just said "whatever your homeomorphism is, the direction that goes from R+ x R into R+ x R+ , call it F, won't be differentiable at F-1(0)." The argument I had in mind is the following. For the sake of clarity, suppose that F-1(0)=0. Then, the limit defining ∂Fi/∂x at (0,0) will be different as you approach from the right and from the left.
I doubt that it is, but it is a good criterion for deciding if a map is non-smooth :)
Yes, it seems to be essentially the same as the argument I wrote.
Now it is quite clear, thank you again!
If you have two manifolds with boundary I think the product will be a manifold with corners.
I am thinking of the product of two closed intervals. This resulting rectangle has four corners. At the corners I wonder what happens.
  • · Replies 38 ·
9K
  • · Replies 31 ·
