Comparing Cooling Rates of Solid and Hollow Spheres
  • Context: Undergrad
  • Thread starter Thread starter vkash
    Cooling Solid Spheres
The discussion centers on the cooling rates of solid and hollow spheres of identical radius when heated to the same temperature. It is established that both spheres emit the same power at the same temperature; however, the hollow sphere has a smaller heat capacity. Consequently, the hollow sphere cools at a faster rate than the solid sphere due to its ability to lose heat more rapidly despite both starting at the same temperature.
  • Understanding of thermal dynamics and heat transfer principles
  • Familiarity with concepts of heat capacity and thermal conductivity
  • Knowledge of the properties of solid and hollow objects
  • Basic principles of thermodynamics
  • Research the concept of heat capacity in materials
  • Explore the laws of thermodynamics related to heat transfer
  • Learn about the cooling rates of different geometric shapes
  • Investigate practical applications of thermal dynamics in engineering
Students and professionals in physics, engineering, and materials science who are interested in understanding heat transfer and thermal dynamics in solid and hollow structures.
vkash
There are two sphere of same radius but one is solid and other is hollow. Both are heated to same temperature(greater than room temperature). which will cool at faster rate?
I think both the spheres will cool at same rate since hollow sphere can't loose it's heat inside it (because internal temperature is also same as that of sphere) so both the spheres have same sink so they should cool at same rate.
however after little time their rate should vary because hollow sphere may have lesser energy..
IS my explanation correct?
Science news on Phys.org
You are right: at the same temperature both emits the same power. But the hollow one has smaller heat capacity, so - emitting the same power it cools faster.
OK!
thanks for confirming...
  • · Replies 32 ·
