| New Reply |
Magnetic Fields from Currents in a Wire and a Cylindrical Shell |
Share Thread | Thread Tools |
| Mar10-12, 04:14 PM | #1 |
1. The problem statement, all variables and given/known data
A solid cylindrical conducting shell of inner radius a = 5.3 cm and outer radius b = 7.9 cm has its axis aligned with the z-axis as shown. It carries a uniformly distributed current I2 = 7.1 A in the positive z-direction. An infinite conducting wire is located along the z-axis and carries a current I1 = 2.7 A in the negative z-direction. What is [itex]\int[/itex][itex]^{P}_{S}[/itex] [itex]\vec{B}[/itex] . [itex]\vec{dL}[/itex], where the integral is taken on the straight line path from point S to point P as shown? Link to the picture: http://i89.photobucket.com/albums/k2...cylindersD.png 2. Relevant equations 3. The attempt at a solution I'm not even sure how to approach this problem. At first I found the difference between the values of the magnetic field at P and at S, but this was wrong. Then I thought to use ∫[itex]\vec{B}[/itex] . [itex]\vec{dL}[/itex] = μoI but B is not constant over the interval [S,P] so I can't pull it out of the integral. I was able to calculate the integral along the dotted path in the picture, which I basically did by realizing R to S was perpendicular to the field so it didn't count, and that P to R was 1/8 of a larger circle drawn around the diagram. But in this case, B was a constant distance from the centre. Any input is appreciate. Thanks! |
| Mar10-12, 05:33 PM | #2 |
hi diethaltao!
![]() how about doing it along a path 8 times as long, in a square?
| Mar10-12, 06:44 PM | #3 |
Hi tiny-tim!
So, I would find r using the Pythagorean Theorem: r = [itex]\sqrt{((0.21)(0.6))^2+(0.21-(0.21)(0.6))^2}[/itex] = 0.151. So I would multiply the field (which I found at point P to be 4.19E-6) by the perimeter of the square? And the perimeter would be 8R...? Obviously I messed up somewhere. |
| Mar11-12, 05:36 AM | #4 |
hi diethaltao!
![]() (just got up ) why do you want to know the field? try using the Ampere-Maxwell law |
| Mar11-12, 12:54 PM | #5 |
Hi tiny-tim!
Ampere-Maxwell's law says that [itex]\vec{B}[/itex].[itex]\vec{dL}[/itex] around a closed loop is proportional to the current enclosed in that loop, or [itex]\oint[/itex][itex]\vec{B}[/itex].[itex]\vec{dL}[/itex] = μo*Ienc. But I can't just plug in the values of μo and Ienc to solve for the integral. And if I choose a square to be my enclosed area, B wouldn't be the same along the side, correct? For example, the field at point S would be stronger than at point P. |
| Mar11-12, 02:42 PM | #6 |
then ∫ B.dl along PS will be the same as ∫ B.dl along ST, won't it?
| Mar11-12, 09:17 PM | #7 |
Ok, I understand that.
So now I have something like the picture attached, where R is the hypotenuse of a 0.21 by 0.21 triangle (not sure if I need that value, but I calculated it anyways.) The integral from P to S is the same as the integral of T to S. And therefore, the integral from P to T would be the same as it would be for the other three sides of the square. I tried integrating around the whole square and dividing it by 8, but that was incorrect. http://i89.photobucket.com/albums/k2...o/Untitled.png |
| Mar12-12, 02:22 AM | #8 |
hi diethaltao!
![]() use the Ampere-Maxwell law … ∫ B.dl = … ? |
| Mar12-12, 10:58 PM | #9 |
Oh, wow, I get it now.
Can't believe I overlooked something so simple! Thanks so much!
| New Reply |
| Tags |
| ampere-maxwell law, cylindrical shell, infinite wire, magnetic fields, magnetism |
| Thread Tools | |
Similar Threads for: Magnetic Fields from Currents in a Wire and a Cylindrical Shell
| Thread | Forum | Replies | ||
| Magnetic Fields from Currents in a Wire and a Cylindrical Shell | Introductory Physics Homework | 5 | ||
| currents and magnetic fields | Introductory Physics Homework | 4 | ||
| Currents and magnetic fields | Introductory Physics Homework | 2 | ||
| Currents and Magnetic fields | Introductory Physics Homework | 1 | ||
| Currents and magnetic fields | Introductory Physics Homework | 4 | ||
