New Reply
Electronic partition function for molecule with degeneracies
Share Thread
Mar12-12, 02:46 PM   #1
1. The problem statement, all variables and given/known data
A atom had a threefold degenerate ground level, a non degenerate electronically excited level at 3500 cm^-1(setting the energy orgin as the ground electronic state energy of the atom ) and a threefold degenerate level at 4700 cm^-1 . Calculate the electronic partition function of this atom at 2000K
2. Relevant equations
qel= sumnation{i=0inf}[gel*exp[-(Ei-Ei-1)/(kbT)]]
3. The attempt at a solution
I see three levels in the problem
I believe, given the problem statement, that g0=3, g1=1 @3500cm-1, g2=3@4700cm-1
I came up with the equation
qel= 3+ 1*exp[-(E1-E0)/(kbT)] + 3*exp[-(E2-E1)/(kbT)]
T= 2000K, kb= boltzmann constant ~1.38e-23
I am having trouble finding the energy values for each excited state. I am not sure if E=hv applies to this problem.
Also I am not too confident in the equation I found.
If anyone understands degeneracy, electronic partition functions or excited electronic stateI would greatly appreciate any help
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar12-12, 10:44 PM   #2
Recognitions:
Homework Helper Homework Help
I would assume that you just use
E = h f
= h c / lambda
= hbar c k
, no? (I'm assuming that the inverse lengths that the problem specifies are wavenumbers of photons that would be emitted from the corresponding energy differences.)
Mar13-12, 12:12 PM   #3
yes I guess I can just multiply those numbers by c to get the excited state energies. Doing this it seems that all the exponentials go to zero because kbT is so small and c is so large. I guess the electronic partition function ends up being equal to 3
Mar13-12, 08:16 PM   #4
Mentor
Quote by wiveykid View Post
There is more to the calculation than just kBT and c. Try calculating the value of [itex]\frac{\Delta E}{k_B T}[/itex] for the two excited states.
That's pretty much correct, except that it is E2-E0 in the final term.
Yes, it does.
New Reply
Similar discussions for: Electronic partition function for molecule with degeneracies
Thread Forum Replies
What's happen when a molecule or an atom is already in an excited electronic state an Quantum Physics 8
partition function Classical Physics 2
Partition Function p(n) General Math 20
Partition function Classical Physics 0
Partition function of rotating molecule Classical Physics 0
