New Reply
ADC vocabulary question
Share Thread Thread Tools
Mar12-12, 03:09 AM   #1
what do you call the digital number that analog to digital converters output ?
Does it make any sense to call it "analog signal's digital representation" ? Is there a better way to call it?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Mar12-12, 06:02 AM   #2
Recognitions:
Gold Membership Gold Member
Quote by david90 View Post
Its called a binary output
the number of bits, from the LSB (Least Significant Bit to the MSB Most Significant Bit) that binary code has for each sample is a function of the design of the ADC chip ie. whether its a for example a 8 bit, 16 bit or say 24bit system.
the more bits the higher the resolution and the larger the input signal it can handle befor it clips. For example, an ADC with a resolution of 8 bits can encode an analog input to one in 256 different levels, since 28 = 256.
Initially my digital seismograph system used 12bit resolution (4094 datapoints) and it would often clip on the large signals from the big earthquakes. I upgraded the ADC system to a 16bit one now I have 65536 datapoints.
hope that waffle helped :)
Dave
Mar12-12, 07:55 AM   #3
Recognitions:
Quote by davenn View Post
Dave
It doesn't need to be binary. The general term would be 'digital' or even 'quantised' output.
The term "representation" is a good one because it gets over the idea that it's information that's involved.
Mar12-12, 10:10 AM   #4
Engineering 2012
Recognitions:
Indeed, while one will most often encounter a binary representation it may be in any of several formats.
Once ran across one that gave result as an ASCII character string representing the millivolts, complete with decimal point .
Never saw one that gave Roman Numerals, though.
Mar12-12, 10:15 AM   #5
Recognitions:
And BCD was popular, too.
Jim - your eyes are beginning to mist over again. . . .
Mar12-12, 02:39 PM   #6
Digitized Signal
Mar12-12, 06:08 PM   #7
Engineering 2012
Recognitions:
You know, they just don't make nostalgia like they used to.
old jim
Mar13-12, 06:49 PM   #8
Recognitions:
Quote by jim hardy View Post
ASCII never come across one with an ASCII output
we learn every day :)
Dave
New Reply
Thread Tools
Similar Threads for: ADC vocabulary question
Thread Forum Replies
Vp vocabulary Set Theory, Logic, Probability, Statistics 0
Ancient Vocabulary Linear & Abstract Algebra 9
Question of vocabulary Differential Geometry 1
Math vocabulary General Math 2
Simple question of vocabulary General Physics 3
