| New Reply |
Magnetic Field Circuit Problem |
Share Thread | Thread Tools |
| Mar6-12, 08:28 AM | #1 |
1. http://www.webassign.net/userimages/...4net&id=110544
A square loop consists of a single turn with a resistance of 5.00 ohms. The loop has an area of 500 cm2, and has a uniform magnetic field passing through it that is directed out of the page. The loop contains a 12-volt battery, connected as shown in the figure above. (a) At the instant shown in the figure, there is no net current in the loop. At what rate is the magnetic field changing? Use a positive sign if the field is increasing and magnitude, and a negative sign if the field is decreasing in magnitude. T/s (b) If the polarity of the battery was reversed, and the magnetic field was still changing at the rate you calculated above, what would the magnitude of the net current through the loop be? A 2. Faraday's Law and Magnetic Flux Flux=ABcos(theta) emf=N*change in flux/change in time V=IR 3. I was able to solve for part A using a combination of the first two equations to solve for Magnetic field/ time. However, I am having trouble understanding the second part. If the rate of change in magnetic field is same, isn't emf still 12V and the resistance 5 ohms? I know that 12/5 for the ohm's law does not result in the correct solution. Thanks for your help. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Mar6-12, 10:01 AM | #2 |
Bump~
| Mar8-12, 06:56 PM | #3 |
Bump~~
| Mar9-12, 10:47 AM | #4 |
bump``
| Mar9-12, 08:59 PM | #5 |
Recognitions:
Voltages in series add or subtract. The loop generates the same emf as before, but now the battery contributes its 12v so that the two voltages add.
What is the correct answer? |
| Mar11-12, 01:16 PM | #6 |
How do you solve for a?
I did the following: induced emf e = - N dφ/dt flux φ = B * A ( A is the area of loop) e = - 1 * d( B * 0.5m^2 ) /dt -12 = - 0.05 * dB/dt dB/dt = 12/.05 = 240 T/s Why is this incorrect? It asks for magnitude so sign shouldnt matter anyways. |
| Mar13-12, 08:46 PM | #7 |
Recognitions:
Using this relation, |
| Mar13-12, 08:50 PM | #8 |
Recognitions:
| Mar13-12, 08:51 PM | #9 |
Oh, I am not sure if I'm in the same class or not and my problem is that I DON'T know what the correct answer is BUT I do know mines is the wrong one.
Thanks for the help let me think/try it now. |
| Mar13-12, 09:13 PM | #10 |
I still don't get it. Is my math wrong?
| Mar13-12, 09:43 PM | #11 |
Recognitions:
240 T/s looks right.
| Mar15-12, 11:48 AM | #12 |
| Mar15-12, 03:11 PM | #13 |
oh yeah i was given 500cm^2 but that still converts to 0.05m^2 so it was just a slip of the hand, I still dont see what else is wrong.
| Mar18-12, 09:42 PM | #14 |
you need to include the minus sign!
| Mar18-12, 09:43 PM | #15 |
my problem asks for magnitude.
| New Reply |
| Thread Tools | |
Similar Threads for: Magnetic Field Circuit Problem
| Thread | Forum | Replies | ||
| Magnetic Field Circuit Problem | Introductory Physics Homework | 2 | ||
| Magnetic Field at center of circle on rectangular circuit | Introductory Physics Homework | 1 | ||
| Falling circuit in a magnetic field | Introductory Physics Homework | 1 | ||
| Magnetic Field in LC circuit | Classical Physics | 4 | ||
| Circuit/magnetic field | Advanced Physics Homework | 5 | ||
