| New Reply |
Finding the radius of a circle in a graph! |
Share Thread | Thread Tools |
| Mar14-12, 09:23 AM | #1 |
1. The problem statement, all variables and given/known data
A circle of maximal area is inscribed in the region bounded by the graph of y = -x^2-7x+12 and the x axis. The radius of this circle is of the form (sqrt(p) + q)/r where, p, q and r are integers and are relatively prime.What is p+q+r 2. Relevant equations Vertex form a(x-h)^2+k i believe 3. The attempt at a solution So i found the vertex, then i assumed that is one point on the circle, and the other is at (same x,0) then shifted along that but i dont seem to get it of the form sqrtp+q all over r |
| Mar14-12, 11:27 AM | #2 |
I'd suggest trying to use the distance formula for the radius. Not too sure about this but wouldn't the centre of the circle be at the (h,(k/2))? Would you happen to have the answer (from the solution manual or something)?
| Mar14-12, 11:33 AM | #3 |
yes it would be h,k/2
But you get the vertex to be (-97/2,-7/2) So the radius would just be half the y coordinate, but it doesent really fit the condition of the sqrtp and such part. I think the maximization case i picked is wrong |
| Mar14-12, 01:31 PM | #4 |
Mentor
newchie,
You are assuming that the circle and parabola coincide at the vertex of the parabola. I'm not sure that this is true, although it might be. If the curvature of the parabola at the vertex is greater than the curvature of the circle, the circle won't be inside the parabola, hence won't be inscribed in the parabola. |
| Mar14-12, 02:18 PM | #5 |
Yes my error,
Do you have any ideas on how to maximize this I really am stumped o.op |
| Mar14-12, 02:42 PM | #6 |
Mentor
What class are you taking? Is it a calculus class or one that comes before calculus? The type of class you are in will determine the approaches that are available.
| Mar14-12, 02:49 PM | #7 |
| Mar14-12, 07:18 PM | #8 |
Mentor
It makes sense that the circle with maximal area will be tangent to the parabola at two points, both with the same y coordinate. --- or possibly tangent at only one point if that's the vertex. The maximal circle should also be tangent to the x-axis at x = -7/2, the same x value as the vertex. Let A be the radius of the circle. You can assume the center of the circle has the same x coordinate as the vertex of the parabola, namely, -7/2 . Then the center of the circle is at (-7/2, A). What is the equation for such a circle? Determine where the circle & parabola intersect. |
| New Reply |
| Thread Tools | |
Similar Threads for: Finding the radius of a circle in a graph!
| Thread | Forum | Replies | ||
| Proving a quadrilateral is cyclic and finding the radius of the circle | Calculus & Beyond Homework | 1 | ||
| Finding radius of circle inscribed in a triangle | Precalculus Mathematics Homework | 1 | ||
| finding the Center and Radius of a circle | Calculus | 1 | ||
| Completing the Square/Finding Center & Radius of Circle | Precalculus Mathematics Homework | 7 | ||
| circular loop problem: finding the radius of a small circle | Advanced Physics Homework | 5 | ||
