New Reply
Example question on pressure of liquids
Share Thread Thread Tools
Mar16-12, 04:38 AM   #1
This question seemed a bit abstract to me, maybe some of you could come up with an answer with explanation?
When designing a dam should one consider the horizontal extent of the water behind the dam or the vertical depth of the water? Justify your answer.
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Mar16-12, 04:57 AM   #2
Hi Jayadds,
Do you mean the length of the dam wall?
Mar16-12, 05:26 AM   #3
Quote by Hassan2 View Post
Hi Jayadds,
Yes, I mean the length of the dam wall as well as the thickness.
Mar16-12, 05:44 AM   #4
Quote by jayadds View Post
I'm not an expert in this field but according to my limited knowledge, the length of the wall does matter because the total force on the wall is proportional to area and the area is proportional to the wall length as well as to the water depth ( thickness). But a more detailed explanation is about stress and strain of the wall under the forces. Long dams are build oval-shaped or in other curved surfaces to resist the forces.
Mar16-12, 07:23 AM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi jayadds!
When designing a dam should one consider the horizontal extent of the water behind the dam …
i think that means, how far away the water extends from the dam
Mar16-12, 09:56 AM   #6
Depth determines pressure, not volume. This means that whether you're at the bottom of the ocean or at the bottom of a narrow well, as long as the water depth is the same, the pressure and force on you will also be the same.
Mar16-12, 10:05 AM   #7
Quote by tiny-tim View Post
hi jayadds!
This.
And to answer the original question with another, just think about it a bit. What affects the pressure, how deep you are or how much water you have around you?
New Reply
Thread Tools
Similar Threads for: Example question on pressure of liquids
Thread Forum Replies
Pressure in liquids question Introductory Physics Homework 2
Gauge pressure question w/ 2 liquids. Introductory Physics Homework 0
Pressure in liquids Classical Physics 2
difficult question on pressure in liquids Introductory Physics Homework 29
Why is the pressure of two different liquids in a manometer the same? General Physics 1
