| New Reply |
Holomorphic Maps on D(0,1) |
Share Thread | Thread Tools |
| Mar7-12, 10:43 PM | #1 |
Recognitions:
Hi, I know this one is not too hard, but I've been stuck for a while:
Say f is holomorphic and non-constant on the closed unit disc D(0,1), and |f|=1 on the boundary of the disk (so that, e.g., by the MVT, f maps the disk into itself) . Is it the case that f maps the disk _onto_ itself? I have thought of trying to show that the integral: ∫_D (f'(z)dz/(f(z)-a ) is non-zero , for a in the interior of D. i.e., the winding number of f(z) about any point on the disk is non-zero. But I can't see how to show this. Any Ideas? I am trying to use the fact that if f is analytic, then f is a finite product of Blaschke factors , but it still does not add up. Any ideas? Thanks in Advance. |
| Mar8-12, 12:42 AM | #2 |
Recognitions:
It suffices to show that f is not constant on the boundary of the disk I believe. But a non constant map is an open map, so.....? I guess then the image of the closed disc is both closed and open in the closed disc, hence everything?????
Think this through, is it right? does it need amplification? |
| Mar8-12, 12:18 PM | #3 |
Recognitions:
I don't see how it follows that f(D(0,1)) is both open and closed; I agree if I could show this, it would be a proof, by connectedness.
| Mar15-12, 09:46 PM | #4 |
Recognitions:
Where in the interior of the disk could f(z) be outside of the disk?
| Mar16-12, 06:47 PM | #5 |
Recognitions:
You have to use fact that f(z) is analytic ; otherwise points inside can be mapped outside.
| Mar16-12, 07:28 PM | #6 |
Recognitions:
Besides, the more difficult part , as I see it, is how to show that the boundary does wind about every point inside. This has to see with non-constant analytic maps being open, but I cannot see how to show that the winding number about every point inside is non-zero.
| Mar17-12, 07:23 AM | #7 |
Recognitions:
A non-constant holomorphic function can not have it's maximum in the interior of the unit disk,
| Mar20-12, 04:14 PM | #8 |
Recognitions:
Yes, that is true, but how does it help?
| Mar20-12, 05:13 PM | #9 |
Recognitions:
But then it is a map from a 2 dimensional domain onto a 1 manifold so the Jacobian must be everywhere singular. But The Jacobian is multiplication by a complex number and so must be zero. I think ..... |
| Mar20-12, 10:55 PM | #10 |
Recognitions:
| Mar21-12, 07:42 AM | #11 |
Recognitions:
So the norm of f is less than or equal to 1 on the closed disk. On the interior it is less that 1 unless it is a constant. You were right to correct me. I was assuming that f is non zero in which case you can assume the Minimum Modulus Principle. In that case, the map must be a constant. My mistake. |
| Mar22-12, 09:00 PM | #12 |
Recognitions:
What can you say about the boundary points of the image? This should help you prove that it's open and closed.
| Mar22-12, 09:28 PM | #13 |
Recognitions:
Yes, thanks, but I'm trying to help someone who must somehow use ( instructions in the qual. exam prep. exercise), the winding number. So all I can think is showing that the image of the boundary of the disk winds around every point in the disk. All I can think with those tools are Blaschke products, but I cannot see how .
| Mar23-12, 05:30 PM | #14 |
Recognitions:
Thanks, all. My apologies for not being more clear. Unfortunately, for the May Quals. my friend is taking, one must follow the instructions more closely than the September exams.
| Mar23-12, 10:08 PM | #15 |
As you noted, for any curve γ, [itex]\int_\gamma \frac{f'(z)}{f(z)-a} \mathrm{d}z[/itex] is simply 2πi times the winding number of [itex]f \circ \gamma[/itex] around the point a. But the winding number is constant on each connected component of the complement of the image of [itex]f \circ \gamma[/itex]. Now, you are given that |f(z)| = 1 for |z| = 1. So if γ is the curve that goes once around the unit circle, the image of [itex]f \circ \gamma[/itex] is contained in the unit circle. Now, if a and b are any two points in D(0, 1), they can be connected by a straight line that does not intersect the unit circle, so they must be in the same component of the complement of the image of [itex]f \circ \gamma[/itex]. Ergo [itex]\int_\gamma \frac{f'(z)}{f(z)-a} \mathrm{d}z = \int_\gamma \frac{f'(z)}{f(z)-b} \mathrm{d}z[/itex]. So you only have to show that this integral is nonzero at at least one point in the unit disk, and it follows that it is nonzero at all points.
| Mar25-12, 10:28 PM | #16 |
Recognitions:
Nice Job: continuous, integer-valued functions are locally-constant. Good one, Citan.
| New Reply |
| Thread Tools | |
Similar Threads for: Holomorphic Maps on D(0,1)
| Thread | Forum | Replies | ||
| Holomorphic on C | Calculus & Beyond Homework | 35 | ||
| Holomorphic Quotient Maps on Projective Space | Calculus & Beyond Homework | 0 | ||
| Integral of holomorphic function in 2 variables is holomorphic | Calculus | 7 | ||
| Linear Maps/Matrix Maps | Engineering, Comp Sci, & Technology Homework | 2 | ||
| holomorphic map | Calculus | 7 | ||
