| New Reply |
automaticly shorting circuit |
Share Thread | Thread Tools |
| Apr5-12, 02:56 AM | #1 |
hi everybody. i need a circuit which will short 2 cables for 0.5 seconds every second. let me explain like this:
_______________ (+2.4v) | | (0) -----------| |-------------- | | ----------------- in the ugly drawing above you can see two wires with a potential difference of 2.4 volts connected to a box. the box just represents the circuit that i want to make with your help. this box must have zero resistance for 0.5 seconds and infinity resistance for 0.5 seconds. so its like a pulsating current with 1Hz across this two wires. Can you guys help me with this ? i have circuit elements like resistor, capacitor, leds, transistors(only BDX53C, BD243C, TIP41C and BDX54C), and etc... The timing doesnt have to be so strict, 0.5s+-0.05 is fine. The current that will be drawn during shorting is not high, not higher than 100ma. I need the simplest and most efficient circuit that you know :) |
| Apr5-12, 02:59 AM | #2 |
sorry about that drawing, it didnt come out like i wanted. here is correction:
2.4v ----------------|BOX|--------------- 0 |
| Apr5-12, 05:13 AM | #3 |
Simplest?
Put BD243C npn transistor across those cables(collector to 2.4V side). Use a 555 timer for sending square wave pulses to base. ![]() Here are the values for 555 timer. |
| Apr5-12, 05:12 PM | #4 |
You could always drive a little reed or telecom relay if desired. Those are pretty quick and will give as close to a dead-short as you can get.
The 555 timer circuit above should be able to drive one of those without issue. |
| Apr6-12, 09:14 AM | #5 |
If you suspect you may need to alter timings etc and dont mind spending a few extra pounds you con get a simple logic controller with relay outputs, a basic logic programme will give you an unlimited output function with easy alterations and time scaling down to the thousands of a second.
You can get a starter kit and i promise you, you'll have programmed it within the hour even with no experience, the best thing is you can save the programme and load a new one for your next project. |
| New Reply |
| Tags |
| 1 hz, ampere, short circuit, timing, volt |
| Thread Tools | |
Similar Threads for: automaticly shorting circuit
| Thread | Forum | Replies | ||
| shorting neutral to earth confusion | Engineering Systems & Design | 4 | ||
| shorting of digital high and ground | Electrical Engineering | 2 | ||
| Shorting a switch elctrically | Electrical Engineering | 15 | ||
| automaticly resolve spring equation | Differential Equations | 0 | ||
| Does quickly shorting out an inductor in series with a capcitor create a small emp? | Electrical Engineering | 7 | ||
