New Reply
Collisions mechanics question
Share Thread Thread Tools
Apr16-12, 03:59 AM   #1
A smooth spherical particle with mass 2.5 kg collides with a second smooth spherical
particle of mass 6kg. Before the collision, the first particle has velocity 9ms^1
in the positive x-direction while the second particle has velocity 6ms^1 in the positive y-direction. At the instant of collision, the particles are so that the normals to their surfaces at the point of contact are ±n, where n
is a unit vector inclined at -pi/4 from the x-axis as shown. You may assume that the coefficient of restitution e = 2/3 and that no other forces are involved. Determine the velocities v1,1 and v2,1 of the first and second particles respectively, immediately after the collision.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr16-12, 04:09 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi ly667! welcome to pf!
show us what you've tried, and where you're stuck, and then we'll know how to help!
Apr16-12, 04:20 AM   #3
I dont really have much of an idea to be honest, nor do my classmates. We have been looking at it all night :(
Basically what I have so far is.. I have constructed my diagram.
Particle 1: m1=2.5, v1=9
Particle 2: m2=6, v2=6
Particles interact along line, to n=v1-v2
we also need m, a vector perpendicular to n
m=v1+v2 (so m.n=0)
Physical assumptions: momentum conservation
coeff of rest 2/3
smooth collisions
Apr16-12, 04:33 AM   #4
Recognitions:
this is an inelastic collision
so you need conservation of momentum in two perpendicular directions (either x and y, or n and z×n)
and one more equation, which will be the coefficient of restitution equation
(the coefficient of restitution is the ratio of the relative speed after to the relative speed before the collision, see the pf library)
show us what you get
Apr16-12, 05:13 AM   #5
Okay, so far I have
Mathematically condition i.) gives
m1,v1,0+m2v2,0=m1,v1,1+m2v2,1
ie. 2.5(v1,1)+6(v2,1)=22.5+36 = 58.5
while ii.) gives(v2,1-v1,1)= e(v2,0-v1,0).n
and iii.) gives (v2,1-v1,1).m= (v2,0-v1,0).m
=0 since n=v2,0-v1,0
Its easiest to work in components
let v2,1=9u2+6w2
and v1,1=9u1+6w1
momentum cons becomes
2.5(9u1)+2.5(6w1)+6(9u2)+6(6w2)=58.5
I am stuck and dont know what to do from here.. Is what I have done correct?
Apr16-12, 05:23 AM   #6
Recognitions:
Quote by ly667 View Post
ah, no wonder you're stuck, your professor obviously hasn't explained to you the vector nature of conservation of momentum
your 58.5 is the sum of the x and y components of momentum …
you can't do that!!
momentum is a vector, and obeys the laws of vector addition
you can't add components in different directions
write out two equations, one for conservation of momentum in the x direction, and one for conservation of momentum in the y direction
Apr16-12, 05:31 AM   #7
So should I use my velocity value as vectors, ie instead of v1=9, let it equal 9i?
Apr16-12, 05:34 AM   #8
Recognitions:
yes
Apr16-12, 05:36 AM   #9
Okay :) thank you!! Will do that now! Could you please help me with my collisions question? I have gotten a good bit of it done but am stuck at a point!
New Reply
Tags
collision, math, mechanics, physics
Thread Tools
Similar Threads for: Collisions mechanics question
Thread Forum Replies
Collisions mechanics question Classical Physics 1
Rotational Mechanics & Collisions question Introductory Physics Homework 6
Another question about collisions in 2 and 3-d... Introductory Physics Homework 0
Question on collisions Introductory Physics Homework 3
