| New Reply |
Calculating Distance From a Falling Stone |
Share Thread | Thread Tools |
| Apr17-12, 08:50 AM | #1 |
Ok, so I watched a horror movie recently and they did the whole drop a rock down a cavern and see how long it took to hit the bottom. Couldn't you find the approximate distance through this? Not just a guess like "Oh that took a little bit so it's waaaay down there".
If two objects accelerate at the same rate due to the pull of gravity, if you could calculate the speed, wouldn't it pretty much be used as an assumed constant? Then if you knew the speed, all you would have to do is divide that by the time it took to hit the bottom using Speed= Distance x Time. But then again, if you were at a higher point and dropped it, wouldn't it have more space to accerlate and throw off your results? I'm just looking for an estimate, it doesn't have to be exact. |
| Apr17-12, 09:08 AM | #2 |
The formula is simple:
assuming zero initial velocity, the distance, s, fallen is: s = (1/2)(-gt^2) |
| New Reply |
| Thread Tools | |
Similar Threads for: Calculating Distance From a Falling Stone
| Thread | Forum | Replies | ||
| Distance between falling object | Introductory Physics Homework | 5 | ||
| Initial speed of a thrown/falling stone | Introductory Physics Homework | 8 | ||
| finding the distance for one stone to pass the other | Introductory Physics Homework | 1 | ||
| stone falling from moon's orbit | Astrophysics | 8 | ||
| A Falling Stone | Introductory Physics Homework | 6 | ||
