Conservation of momentum when bouncing a ball
The discussion revolves around the conservation of momentum in the context of a ball bouncing off a wall. Participants explore the implications of external forces, the definitions of impulse and force, and the conditions under which momentum is considered conserved during collisions.
  • One participant questions how momentum is conserved when a ball of mass m traveling with velocity v bounces back with velocity -v, leading to a perceived discrepancy in total momentum.
  • Another participant suggests that conservation of momentum applies only in the absence of external forces, raising the question of whether the force keeping the wall at rest is considered external.
  • A participant argues that the wall's force does not affect momentum conservation since it is present from the beginning, while others contend that the wall's attachment to the ground introduces external forces that must be considered.
  • There is a discussion about the nature of forces during the collision, with one participant asserting that static friction must be accounted for, complicating the momentum conservation argument.
  • Participants debate the relationship between momentum and force, with one questioning how a momentum of mv could result in a force of 2mv, leading to confusion over the definitions of impulse and force.
  • Another participant clarifies that 2mv represents an impulse, not a force, and explains that force is the change of momentum over time, which can vary based on the duration of the collision.
  • There is a discussion about the average force exerted during the collision, with one participant attempting to relate the impulse to the average force while others challenge the reasoning behind the calculations.
  • One participant emphasizes that comparing force and momentum directly is incorrect due to their different units, while another attempts to clarify the relationship between the two concepts.
Participants express differing views on whether the wall's force is external and how it affects momentum conservation. There is no consensus on the implications of impulse versus force, and the discussion remains unresolved regarding the definitions and relationships between these concepts.
Participants highlight the arbitrary nature of defining the system in terms of internal and external forces, which complicates the analysis of momentum conservation. The discussion also reflects uncertainty regarding the time duration of the collision and its impact on force calculations.
yoelhalb
Hi all.
I am learning physics and I have the following problem.
Suppose there is a ball of mass m traveling with velocity v towards a wall at rest.
The ball bounces back and it's now at velocity -v.
Since the wall is always at rest, it follows that the total momentum before the collision was mv, but after the collision it is -mv, so how is the momentum conserved?
It is clear that I am doing something wrong or missing something simple, but I can't spot what.
Any help
hi yoelhalb! :smile:
conservation of momentum only applies if there are no external forces …
in this case, isn't there is a force keeping the wall at rest? :wink:
Good idea, but I really doubt if this is considered an external force.
Consider the proof of the conservation of momentum, it is based on that the force is the derivative of momentum, and that there equal and opposite forces, thus canceling out.
But the wall force is there from the beginning and as such it should have no effect on the momentum?
And in other words since the wall is at rest the net force must be zero, thus it has no effect here
You can take it as an external force or not. If not then you must include what happens to the wall. The wall is attached to the ground - another external or internal force - until you get to include the whole Earth. And yes, the whole Earth will feel the impact of the ball and change momentum, but it would be very hard to detect. The change to the Earth's momentum will exactly compensate for other associated actions: your throwing the ball in the first place, and how the ball eventually comes to rest.
Eh? Why would the wall be exerting a horizontal force before the ball strikes it?
What is considered internal or external depends on what you have defined to be your system, and that is a completely arbitrary choice. If your system is the ball and wall then the force of the Earth on the wall is indeed an external force.
After all you are probably right, and although before and after the collision the net force on the wall is zero, still at the time of the collision we have to add the static friction force to keep it at rest.
As such the force that the ball exerts on the wall is canceled by the static friction force, and we are left with force that the wall exerts (the opposite reaction), thus the total forces do not cancel out, hence momentum is not conserved.
But what triggers me is the fact that the change in the balls momentum is 2mv, and according to the second law this is the amount of force applied.
On the other hand the source that caused the force is the momentum of the ball (that resulted in an equal force from the wall on the ball).
As such it turns out that a momentum of mv caused a force of 2mv, is this possible?
Actually what is the push force that an object with a given momentum exerts?
2mv is an impulse, not a force. It has different units than force.
It can be anything from just larger than 0 to just smaller than infinity, depending inversely on the amount of time that the force is applied and depending proportionally on the change in momentum.
If my understanding if the concepts is correct, then impulse is the change of momentum, while force is the change of momentum with respect to time, and since here the collision was just an instant and the impulse is 2mv then the force must be 2mv/s.
My problem is that this was caused by a momentum of mv!
The momentum that you speak is the resulting momentum, however I am asking about the force caused by a given momentum.
Suppose I have mass v and running with velocity v and momentum mv towards another object, is there a way to predicate the push force that I will exert on the object when I will push it?
The reason that I asked it here is because I have seen that the momentum mv of the ball resulted in a force of 2mv.
This is incorrect reasoning. If the collision was 1s then the average force would be 2mv/(1 s), but as you said the collision was just an instant. So the average force would be 2mv/(1 instant). Presumably 1 instant < 1 s so the average force would be greater than what you wrote.
So what? The force and the momentum are different units, comparing them is like comparing apples and oranges.
No, at least, not without additional information.
Again, this is incorrect. The 2mv is in units of impulse, not force. No matter how many times you repeat it 2mv will never be a force, so you may as well learn it now and stop repeating this mistake you have in your mind. Impulse and force are not the same thing, they have different units.
DaleSpam is correct - The ball moves towards the wall with momentum mv (kilogram-meters per second). It strikes the wall, and is in contact with the wall for, let's say, one tenth of a second. The average force it exerts on the wall is mv/10 (kilogram meters per second squared). By Newton's law, the wall exerts this same force on the ball. If the wall is rigidly connected to the earth, then the earth+wall system will gain momentum in the amount of 2mv, and the ball will lose momentum in the amount of 2mv, giving it a momentum of -mv. Total momentum before was mv, total momentum after is 2mv-mv=mv, so momentum is conserved. Adding a momentum of 2mv to the earth-wall system is like adding a drop of water to the ocean - the mass of the Earth is so large, that you cannot detect any change in the velocity of the earth-wall system. But the ball itself will bounce back, its velocity is radically changed, since its mass is so much less than that of the earth.
sorry for my incorrect notation, but it is an impulse of 2mv and a force of minimum 2mv/s, and it was caused by a momentum of 2mv.
And in other words the momentum caused an impulse twice as it's own.
Consider for example that the ball pushed another ball with twice the mass as the first, and changed the velocity from rest to v, does this makes sense? But this is in effect an impulse of 2mv caused by a momentum of mv.
And just as it doesn't make sense by the two balls, it doesn't make sense to me by the ball and the wall.
Yet I understand that that's the fact, my question is if there is a logical reason for it.
And as part of my question is if there is a logical reason to the fact that we cannot determine the force just by knowing the pushing objects momentum.
No, it is not a minimum force of 2mv/(1 s). If you have a 10 s collision then the average force will be less than 2mv/(1 s) by a factor of 10.
Correct, impulse is the change in momentum, not the momentum itself. In this case the change in momentum is twice the original momentum (and in the opposite direction).
I am not certian of this new scenario, they seem rather non-analogous. In one case you have an elastic collision for a non-isolated system where momentum is not conserved due to the external force, and in this new scenario it seems that you are considering a non-elastic collision (energy is produced) for an isolated system where momentum is not conserved but there is no external force. If I understand your new scenario correctly then it violates Newton's laws.
Newton's laws are the logical reason. Also, you need to be careful not to mix up different terms. In this thread I have seen you mix up momentum and change in momentum and mix up force and momentum. Keep your different concepts straight and apply Newton's laws correctly and you will get the right answer.
First, it is the pushing object's change in momentum which is important, not its momentum. Second, the units are wrong, so you need some other quantity with the right units. In this case the units are off by a factor of time, so you need some characteristic time. Specifically, the duration of the push. With that information you can determine the average force.
I think you are still confusing force and momentum. If you push on an object with a gentle force of 1 Newton for 10 seconds, it will have a momentum of 10 kg-m/sec. If you push on that same object with a strong force of 100 Newtons, but only for a tenth of a second, it will have the same momentum - 10 kg-m/sec.
Just because you know the momentum of something, doesn't mean you know the force that produced that momentum. It could be a gentle force over a long time, or a strong force for a short time.
Its the same with an object that has momentum and transfers that momentum to another object. It transfers that momentum by exerting a force on that other object. But you don't know whether it did that by exerting a gentle force for a long time or a strong force for a short time. In other words, you just don't know what the force was when the momentum was transferred, even though you know what the final momentum is.
Well I will have to settle my mind on that, after all this is probably the reality, although I still find it odd that a momentum of mv (and a collision just lasting a fraction of a second) will result in a change in momentum of 2mv (which is like saying that a momentum of mv caused an impulse of 2mv on another object in just an instant of time, something that all of you agree is impossible, and I don't really see the difference between another object and the same object such as a bouncing ball, unless the conversation of energy is used as a explanation), either way this is it.
Yoelhalb: consider the more realistic view that the ball is soft and springy. This avoids any infinite forces and allows us to analyse the stages of the process.
At first contact, there is no force (since no compression yet).
As the ball continues against the wall, the force increases to a maximum, while the ball slows to a stop. Having stopped the ball, the momentum transferred is +mv to the wall, -mv to the ball.
Now the ball springs back from the wall. In practice, some energy will be lost, so the ball is only accelerated to speed w < v. Momentum transferred is mw, in same direction as before, so total transferred to the wall is +m(v+w).
Now bring the thrower/catcher into the picture. The throw imparted momentum +mv to the ball, so -mv to the thrower and thence to the wall/Earth/thrower system. On catching the returning ball, a further -mw is so transferred. Net momentum change is 0.
Hi.
consider a ball in a massive box in free space. When ball bounces box move pushed and has a too tiny velocity to observe. momentum conserves here. Another example when you pitch a ball you kick Earth so Earth moves with a tiny speed. Momentum conserves here.
Regards.
If I correctly understand the different scenarios, then the difference is the presence or absence of the external force. I.e. You could replace the wall with a second bouncing ball firmly anchored to the ground and still get a wall-like result.
What I am saying is that you wouldn't say that a momentum of mv would result in an impulse of 2mv on another object [and completely different scenario] (provided that the collision time is only an instant).
To show that just consider that an impulse of 2mv on an object with intial zero momentum caused by momentum mv, means in other words raising an object with the same mass m to twice the velocity v resulting in 2v hence 2mv, or raising twice the mass (2m) to the same velocity v, any of them caused by mv for just a fraction of a second.
Just the same it doesn't make sense to me in the case of the bouncing ball which is also an impulse of 2mv caused by a momentum of mv.
But so far it doesn't seem that there is a satisfying answer, so I will have to accept it as it is.
Its because you don't yet have an intuitive idea of momentum. You are thinking of momentum as a force, and wondering how a force can double itself in a collision. Keep solving these kinds of problems, over and over, and soon you will get a feel for momentum and force, and how they are different.
Insofar as it is possible to separate things, it is not the momentum of mv that results in the impulse of 2 mv in this scenario (the impulse is in the opposite direction of the mv). It is the external force (the external force is in the same direction as the impulse). If you had a different scenario with an external force then you certainly could get an impulse of 2 mv on another object.
The key difference is the external force. Pay attention to the external force. Look at the effect of the external force. There is an external force. External force...
How many times do we have to repeat the first answer you received before it sinks in?
  • · Replies 30 ·
  • · Replies 53 ·
  • · Replies 52 ·
