| New Reply |
Center Cap vs Tire Diameter Rotation |
Share Thread | Thread Tools |
| Apr30-12, 12:10 PM | #1 |
Hello all,
Just trying to find a formula and need some help. If a tire is 22 inches in diameter, what are the RPMs of the outer diameter of a 22 inch tire versus the RPMs of the outer diameter of a 2.5 inch center cap, on a car traveling 30 MPH? Are they the same, or are the rotations of the diameter of center cap different than the diameter of the tire? Any help would be appreciated. |
| Apr30-12, 02:19 PM | #2 |
| Apr30-12, 03:13 PM | #3 |
Here is a little more help:
Tangential velocity = [itex]V_{tangent}[/itex] Angular frequency = [itex]\omega[/itex] in revolutions/minute, this must be converted to radians/minute for units to work correctly, which 1 rpm = 6.28 rads/min. Radius = r in inches speed of car = 30mph, so to make units agree, 30mph = 31680 inches/minute And we use the formula: [itex]V_{tangent} = \omega * r[/itex] If you consider the tangential velocity of the point on the tire that contacts the road, this velocity vector will tell you how fast the car is moving. So, [itex]V_{tangent} = 31680 \frac{inches}{minute} = 11in\;*\;\omega[/itex] So now, solve for [itex]\omega[/itex]: [itex]\omega = 31680\frac{inches}{minute} * \frac{1}{11\;inches} = 2880 \frac{rad}{min}[/itex] This is in units of radians/minute, so convert to RPM now: [itex]\frac{2880\;rads}{min}\;*\;\frac{1\;revolution}{6.28\;rads} = 458.6 RPM[/itex] There is also a much simpler way of computing this, if you consider that when a tire travels distance of its circumference, it has completed 1 revolution, and then you can calculate how many of those circumferences (revolutions) must be traveled in an hour to get 30 miles, and then convert to minutes. |
| Apr30-12, 09:25 PM | #4 |
Thank you for your reply DragonPeter. So the rotations are the same for both , it is just the distance that is effected by the radius.
| May1-12, 07:14 AM | #5 |
a greater circumference during one rotation than does an inner point....hence it has to go faster [v = wr] than an inner point.... |
| New Reply |
| Thread Tools | |
Similar Threads for: Center Cap vs Tire Diameter Rotation
| Thread | Forum | Replies | ||
| Comparing pressure of air in a tire installed in a car & a free tire | General Physics | 3 | ||
| rotation around center of mass | Introductory Physics Homework | 1 | ||
| How to calculate tire rotation per sec/min/hour | Introductory Physics Homework | 1 | ||
| Find the radius of a car tire, given the mass of wedged stone & tire rotation in m/s | Introductory Physics Homework | 4 | ||
| Center of Rotation | Introductory Physics Homework | 5 | ||
