| New Reply |
Entropy and Disorder (Crystallization) |
Share Thread | Thread Tools |
| May7-12, 09:33 PM | #1 |
To show that entropy is not the same thing as disorder (what people intuitively accept as disorder) my textbook gives an example of crystallization in a supersaturated solution. And it argues that since both temprature and disorder decrease the entropy must decrease also, but it does not. Hence giving a contradiction to the disorder interpretation:
Also, doesn't the 2nd law say that entropy only tends to increase in an isolated system (it can decrease locally within an isolated system)? So, wouldn't stacking some coins would have sufficed as example? So why give this example in particular?
| May7-12, 10:48 PM | #2 |
Recognitions:
Suppose I have a thimble full of boiling water at 100C and a large block of ice at -10C in a vacuum and I pour the water on the ice and end up with a a solid block of ice at -9.9C. Entropy has increased. Whether disorder has increased depends on how I define disorder. AM |
| May8-12, 08:00 AM | #3 |
Recognitions:
Entropy is used as a driving 'force' for some colloidal crystallization experiments- arranging "large" colloid particles in a crystalline array increases the available volume for "smaller" particles.
http://www.google.com/url?sa=t&rct=j...bDjbENGJLIuVbQ http://www.google.com/url?sa=t&rct=j...riQzoc8mf0RAcA http://www.google.com/url?sa=t&rct=j...h1_yaj1aZo7V-Q |
| May9-12, 07:38 AM | #4 |
Recognitions:
Can you find an example where the crystallisation is accompanied by a temperature drop (or, at least, no increase)? I can't.
| May9-12, 07:45 AM | #5 |
Recognitions:
It depends on what you mean by 'temperature'- seriously. For example, hard sphere colloids experience phase transitions between fluid and crystal even when the system is isothermal. The 'temperature' of a hard-sphere colloid is a measure of the volume fraction of spheres, not the thermal energy.
| May9-12, 08:06 AM | #6 |
Recognitions:
| May9-12, 08:09 AM | #7 |
Recognitions:
| May9-12, 05:44 PM | #8 |
Recognitions:
| May9-12, 06:43 PM | #9 |
Recognitions:
| May10-12, 02:49 AM | #10 |
Recognitions:
| May10-12, 03:59 AM | #11 |
Recognitions:
http://en.wikipedia.org/wiki/Solubility it can be seen that solubility increases for most substances with temperature. By van't Hoff equation, it can be infered that the reaction is endothermic. On the other hand crystallization will be exothermic. Exceptions are e.g. Na2SO4 at elevated temperatures or cerium sulfate for which cyrstallization is endothermic. In equilibrium, Delta H=T Delta S, so that in this case entropy really increases in crystallization. At least in the case of Cerium I would speculate that this is due to the highly ordered structure of the water molecules around a highly charged ion like Cerium IV in solution. |
| May10-12, 08:46 AM | #12 |
Recognitions:
| May10-12, 09:49 AM | #13 |
Recognitions:
If the process is athermal then the slope dp/dT of the transition line is 0 or the phase transition allways occurs at the same pressure. I think this is all we can infer from this fact. |
| May10-12, 03:19 PM | #14 |
Recognitions:
Regarding my post #5, all I intended to say was that for certain systems (colloidal suspensions, sandpiles, nonequilibrium systems), the concept of 'temperature' no longer coincides with the common-sense use of the term. Other examples: protein folding, receptor-ligand binding, and cytoskeletal dynamics. Although it's straightforward to analyze the energetics of these processes, I would avoid use of 'temperature' and 'heat'.
| May11-12, 11:53 PM | #15 |
Recognitions:
| May14-12, 06:29 PM | #16 |
The question then is how should one define "disorder"? The kind of disorder the book is talking about is the intuitive meaning (i.e. a crystalline solid is more ordered than its liquid, which is more ordered than its vapor).
| New Reply |
| Thread Tools | |
Similar Threads for: Entropy and Disorder (Crystallization)
| Thread | Forum | Replies | ||
| Questions about examples of why entropy is NOT disorder | General Physics | 7 | ||
| why are there crystals formed when a hot saturated solution is allowed | Biology, Chemistry & Other Homework | 1 | ||
| "entropy is disorder" = outmoded theory?? | Classical Physics | 33 | ||
| Confusion about entropy and disorder | General Physics | 25 | ||
| Entropy (disorder) | Introductory Physics Homework | 6 | ||
