| New Reply |
Japan Earthquake: nuclear plants |
Share Thread | Thread Tools |
| May9-12, 10:02 AM | #13176 |
| May9-12, 10:52 AM | #13177 |
| May9-12, 11:42 AM | #13178 |
half megawatt of decay heat (post 13115) = 500kw X 3412.7 BTU/kwh = 1.706E6 BTU/hr for 5 days = 120 hours X 1.706E6 BTU/hr = 2.05E8 BTU to raise water from (let's guess) 72F to 212F is about 140 BTU/lb so 2.05E8 / 140 = 1.46E6 pounds of water could be warmed that much by the fuel that's 731 US tons of water or 664 metric tons of water i think the pool holds considerably more so i figured it had leaked some. But that was just an assumption. This reference gives 1.5 million liters as typical BWR SFP water inventory http://books.google.com/books?id=ltF...0water&f=false which would be 1.5 million KG , 1500 metric tons, 2.25 X my estimate above. So if it's 'typical' per that book it would have to have lost ~half its water. Dont know if this is of any use at all it's just the kind of rough sanity checks i do on myself to keep that "excess of imagination" from getting me in trouble. please check my arithmetic............. old jim |
| May9-12, 12:51 PM | #13179 |
| May9-12, 01:03 PM | #13180 |
If I remember correctly instrument racks contain the pressure and level transmitters/ analog sensors and those racks are located on the first floor outside of the drywell. The inside drywell piping is routed out to these instruments so there are no wires or junctions inside the containment. No guarantee, but I think 1C55 and 1C56 were the numbers on those racks. Temperature elements are inside containment and thermocouple and RTD cabling is routed out of the drywell and there are junction boxes in the systems inside and outside containment. The Environmental Qualification program qualifies cabling for design basis conditions of pressure, temperature, humidity, spray, submergence, seismic loads, and radiation. However, it is clear that the conditions at the Fukushima plants exceeded design basis conditions. Further the period these instruments are qualified for is not unlimited. I have previously shared the possibility that the post-accident chemistry and radiation are likely attacking the electrical wiring as well. Nuclear plant instrumentation tends to use redundancy, diversity, and independent routing to prevent local failures from being single points of failure. I have been reluctant to weigh in on some of these discussions because they seem too speculative and I am not sure we will gain anything by trying to answer why instruments failed until they can actually retrieve them and do post mortems. I am not suggesting that this discussion isn't valid or interesting. I will try to provide answers on my experience where I can. I am reading these posts and appreciate the effort being made to understand what happened. One of the most important things is to get good simulations of the conditions inside the drywell and torus during the accidents that match the information we actually have. This is likely to be available to develop new qualification requirements well before they can actually start retrieving failed cables or sensors. |
| May9-12, 01:06 PM | #13181 |
steaming carries away copious heat thereafter a half megawatt should evaporate 1760 lbs/hr, or 29 lbs/minute (latent heat 970 BTU/lb) making 785 cubic ft/minute of steam, less than a ten foot cube of course approach to that would be asymptotic as evaporation rate increases. |
| May9-12, 01:30 PM | #13182 |
| May9-12, 04:18 PM | #13183 |
| May9-12, 06:36 PM | #13184 |
Boiling away 1760 lbs/hr would be around 20 tons a day, which is hardly a dent in that 1500 ton inventory. So if the pool was not pretty low on water it got more heat from someplace. Conversely if it got no more heat, it musta been pretty low? i dont know which is the truth, but assumed at the time it was low on water. Again, that was an assumption but it did fit with the 'gamma backscatter' idea as cause of high radiation readings around building, and with high radiation readings from helicopters..loss of water = loss of shielding above spent fuel. But i wasn't there. And there's surely other possibilities. That one could unravel. What's your thoughts? |
| May10-12, 02:31 AM | #13185 |
For the first times, when the internal pressure of the reactor were high that would mean steam condensing in the pool, raising it's temperature: later on as the pressure drops water would flow in and cool the containment cap. Slightly connected: the water in the pool were filtered for cesium and other radioactive elements, but this filtering stopped after some time. Do we have any data about the pool water contamination after the filtering stopped? I think if there is fuel with damaged cladding in the pool then the cesium level would rise after the filtering stopped. If the fuel cladding is intact, the Cs level would be steady. If the fuel cladding is intact then there must have been other source for that Cesium. Maybe from steam coming from the reactor, condensed in the pool? |
| May10-12, 05:24 AM | #13186 |
Next, there's the impeccable assumption: The laws of physics were not suspended in the pool. Then follows the inescapable conclusion: What passed in this case as information from the operator to the agency, and from the agency to the public, was not information, not even false information. It was nonsense. Had it only been false information, that would be understandable. But no, for a statement to be possibly false, it must be implied that it can be possibly a true description of reality. Otherwise the statement is just so much nonsense -- and as your math has shown you, what was reported by the operator and sent on to the public by the agency was postulating a physical impossibility had occurred. All such statements are alike, they express nothing, they are all nonsense. Imagine the operator had reported some other physical impossibility, e.g 'that gravity had reversed over the plant and was emptying the pool', and the safety agency reported this on to the public, the nonsensical nature of it all would have been clear to many people. It takes more knowledge to realise that a 1400 cubic meter pool of water cannot possibly be steaming plumes due to failed cooling after having been heated with 0.5 MW for a couple of days. The unsuspecting and ill-informed public would be excused in not 'getting it'. For Tepco the operator, and for NISA the agency, there is no excuse, and only a few credible explanations, none of which are flattering, and this is not the place to express them. The fact remains, that what we were told about the situation in the pool did not make sense. OK, so back to your considerations. If I get it, you meant to be able to extract as a fact that the pool was boiling from the nonsense "White smoke was seen rising from the vicinity of Unit-3 <..>TEPCO estimates that failing to cool the SFP has resulted in evaporation of pool water, generating steam.", then you added the assumptions that either the pool had lost a lot of water for unknown reasons, or it had an unknown heat source, then you coupled it to the observation of high doserate measured above the building, and got a plausible case of exposed fuel in the pool. But that seems to me to have been assumption upon assumption upon nonsense, and no surprise then that it was all wrong. |
| May10-12, 07:11 AM | #13187 |
Pass on the Cesium thing. IRC the plan has been, using mobile units, with first reverse osmosis, then ion exchangers, to desalinate the water in the pools in turn, starting with unit 4. I do not know where SFP3 would be in the process. |
| May10-12, 07:22 AM | #13188 |
However, steam plumes occur in air very commonly far below the boiling temperature. The air above the surface just has to get a saturation above the prevailing dew point. It is fairly rare in pool applications, but any fisherman can tell you about a misty lake, which is exactly the same effect, but with the lake microclimate as the cool side. |
| May10-12, 08:01 AM | #13189 |
| May10-12, 08:06 AM | #13190 |
Edit: See also the March 16th hourly webcam images |
| May10-12, 09:42 AM | #13191 |
IF that steam indeed came from the pool, there had to be a cause for pool being so hot. With the modest heat input that pool had, either its thermal capacity was less than expected for that much water or the heat input was more than expected. If neither of those is so then the steam came from someplace else. why is that "nonsense" ? EDIT I think one of us misunderstands something the other is saying and our difference lies in semantics not thermodynamics. It is sooooo difficult to make communication precise. old jim |
| May10-12, 01:43 PM | #13192 |
What you have written there is just the sort of mental model one makes of possibilities and logical implications when one is trying to get a foothold in regards of some problem. I wouldn't call any of it nonsense. Otoh, I can't see where you are coming from with it, nor where you are going, also I think the option 'someplace else' might be specifiable both as to its whereabouts, and its logical implications. Better to chalk up the whole playing field, before deciding how to tackle the problem. |
| New Reply |
| Tags |
| japan, nuclear |
| Thread Tools | |
Similar Threads for: Japan Earthquake: nuclear plants
| Thread | Forum | Replies | ||
| 8.9 earthquake in Japan: tsunami warnings | Current Events | 671 | ||
| New Nuclear Plants | Nuclear Engineering | 9 | ||
| Gen IV Nuclear Plants | Nuclear Engineering | 10 | ||
| New Nuclear Plants | Nuclear Engineering | 14 | ||
| Astronomer Predicts Major Earthquake for Japan | General Discussion | 65 | ||
