| New Reply |
Uniform Circular Motion |
Share Thread | Thread Tools |
| May24-12, 04:36 PM | #1 |
I am reading about uniform circular motion currently, but I am sort of confused by this paragraph:
"We next determine the magnitude of the centripetal centripetal (radial) acceleration, ar. Because CA in fig. 5-2a is perpendicular to V1, and CB is perpendicular to V2, it follows that the angle Δθ, defined as the angle between CA and CB, is also the angle between V1 and V2. Hence the vectors V1, V2, and ΔV in fig. 5-2b form a triangle that is geometrically similar to the triangle CAB in fig. 5-2a" I have attached the two figures. Why are the two triangles similar? |
| May24-12, 04:45 PM | #2 |
Mentor
This discussion may help: Centripetal Acceleration |
| May24-12, 04:46 PM | #3 |
Oh, gesh, I am sorry. Thank you for the link.
| May26-12, 07:59 AM | #4 |
I have another question regarding this same topic. I can see mathematically that the radius effects centripetal acceleration, but I was wondering if there was any physical explanation to accompany this mathematical one? Thank you
| May26-12, 08:06 AM | #5 |
Mentor
Does that help? |
| May26-12, 08:20 AM | #6 |
Yeah, I think that does. Thank you very much.
| May26-12, 09:05 AM | #7 |
I am now reading an example problem concerning circular motion. The book says at the topmost part of the circular path, there no tension force required--that is, FT = 0.
It says that that gravity provides the centripetal acceleration. Are the reasons why an object won't fall straight downward due to momentum and there being a horizontal component pushing it forward, back onto the circular path? |
| May26-12, 11:15 AM | #8 |
Mentor
| May30-12, 12:49 PM | #9 |
I have another question regarding circular motion, and I was not sure whether I should ask it in this thread, seeing that it is a bit older--but I'll ask here anyways. I am reading, from a physics website, about circular motion and they give proof that acceleration is directed towards the center of a circle by giving a description of a scenario with an accelerometer. This accelerometer consists of a cork tied a string, with the other end of the string tied to the lid of a capsule, which is full of water. When the accelerometer it is placed on a 2 x 4, and the 2 x 4 is spun around on a platform, the cork will lean towards the center. Now, in a car, we are similar to this cork, but we don't lean towards the center. Is this due to us having greater inertia than the cork?
| May30-12, 01:02 PM | #10 |
In a car, the car, not us, is experiencing an acceleration. While it pushes us along its trajectory, while this isn't very rigorous, our bodies will "try" to keep going along a straight path as predicted by Newton's First Law, and so we'll be leaning outwards. If there's confusion, it's partially because the car going around in circles isn't an inertial reference frame.
| May30-12, 01:05 PM | #11 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: Uniform Circular Motion
| Thread | Forum | Replies | ||
| Do uniform circular motion and non-uniform circular motion have same formula for a? | Classical Physics | 2 | ||
| Vertical circular motion in uniform circular motion | Introductory Physics Homework | 3 | ||
| Uniform circular motion - plane in a circular arc | Introductory Physics Homework | 1 | ||
| Simple Harmonic Motion- From Uniform Circular Motion | Introductory Physics Homework | 5 | ||
| Uniform Circular Motion, Rotational Motion, Torque, and Inertia | General Physics | 1 | ||
