Can I make a motion detector with my limited circuit experience?
  • Thread starter Thread starter Xyius
    Detector Motion
The discussion revolves around the feasibility of creating a motion detector with limited circuit experience, specifically for detecting when someone enters a space, such as a shed. Participants explore various sensor technologies and project ideas, including infrared, ultrasonic, and passive infrared sensors, as well as the challenges associated with each approach.
  • Homework-related
  • One participant expresses interest in using a light-to-frequency sensor with an infrared laser to create a motion detector, questioning the feasibility of this approach given their limited experience.
  • Another participant suggests that while the TSL230 chip is interesting, it may not be suitable for beginners due to the complexity of converting its output into an alarm signal.
  • Some participants recommend off-the-shelf motion sensors available at home improvement stores, which typically use infrared technology and can be modified for DIY projects.
  • Different types of motion detection technologies are proposed, including passive infrared sensors that detect body heat, ultrasonic sensors that measure reflected sound waves, and microwave sensors that operate similarly to radar.
  • Proximity detectors are mentioned as an alternative approach, with references to literature that may provide further insights into sensor technology.
Participants present multiple competing views on the best approach to creating a motion detector, with no consensus on a single method or solution. Some suggest off-the-shelf options while others advocate for DIY projects using various sensor technologies.
Participants highlight the complexity of certain methods, such as the need to filter out unwanted light or the challenges of using specific sensors. There is also mention of literature that could provide additional context, but no specific assumptions or definitions are resolved.
This discussion may be useful for individuals interested in DIY electronics projects, particularly those exploring motion detection technologies or seeking to understand different sensor types and their applications.
Xyius
I am fairly new to circuits, (I am an applied physics major, I have one year left until I get my bachelors) and I thought it would be really cool to make something that shines a light or something if someone crosses past a sensor. For example, if I wanted to know if someone walks into my shed outside, I could set up one of these and if someone does walk in the door a light in my house would illuminate.
My idea (which is probably pretty naive) is the following..
I saw these "light to frequency" sensors at radio shack, I figured I would shine an infrared laser on it and calibrate it to sound an alarm whenever that signal is disrupted. As far as knowing HOW to do this, I do not know. Is this project feasible for someone with my experience? Where can I get the proper sensors? Does anyone have any circuit diagrams applied to something like this I can study?
Thanks!
That TSL230 chip looks really interesting (and the price is very good too), but I don't think it would help you much. The output is a stream of square waves whose frequency depends on the light level. Turning that into an alarm signal would be an interesting project, but not one I would suggest for beginners.
Burglar alarms use circuits which are like you describe, but they have to exclude all light except the light from the wanted source. This is possible, but not easy. You have to shine the light down a tube which lines up with another tube with the sensor in it. Someone walks between the two and an alarm goes off.
Another way is to have the light source pulsing and then exclude all light that isn't pulsing from the detection.
This gives a better result, but is much harder to do.
Here is an example:
http://discovercircuits.com/H-Corner/40khzlight.htm
not a simple project.
Better projects use PIR detectors and ultra sonic detectors.
There are off-the-shelf ready-made motion sensors you could use. Home Depot (or similar) stores sell them as lights that turn on when a person walks into an area. I believe they function using infrared detectors. But whatever method they use, you can simply remove the lamp and install an adaptor to accept your extension cord. Pass that cord into your house and connect the indicator lamp in there!
If you really want to make a DIY project, then you may use one of the following schemes:
Passive infrared sensors (Passive) Looks for body heat. No energy is emitted from the sensor.
Ultrasonic (active) Sends out pulses of ultrasonic waves and measures the reflection off a moving object.
Microwave (active) Sensor sends out microwave pulses and measures the reflection off a moving object. Similar to a police radar gun.
Tomographic Detector (active) Senses disturbances to radio waves as they travel through an area surrounded by mesh network nodes.
http://en.wikipedia.org/wiki/Motion_detector
You can also look at designing proximity detectors which can give you the same result depending on the situation.
The book "handbook of modern sensors" by Fraden has a section called capacitive occupancy detectors that might be interesting to you. It might be a difficult project to get right, but it is simpler in concept.
Handbook of Modern Sensors is a good read for this, so is "Sensor Technology Handbook" by Jon Wilson should help you as well.
Cheers
  • · Replies 0 ·
  • · Replies 152 ·
12K
