| New Reply |
deformation retraction of plane RP2 |
Share Thread | Thread Tools |
| Jun9-12, 05:54 AM | #18 |
Recognitions:
deformation retraction of plane RP2Since any surface is the quotient of a polygon with identifications on the boundary, a single puncture in the middle of the polygon allows a retraction onto the boundary that preserves the identifications. For a compact smooth manifold, I would guess that the exponential map at an point - with respect to any Riemannian metric - maps a connected open set in the tangent space onto the manifold minus a set of measure zero - the cut locus perhaps. The exponential flow defines a deformation retraction of the manifold minus this point onto the set of measure zero. I will research this. An example would be the flat torus. Here the exponential map is just radial flow along straight lines. It retracts the punctured torus onto the cut locus which is a figure 8. What is an example of a manifold that does not have a CW structure? |
| Jun11-12, 06:06 AM | #19 |
Hmm, I may have been wrong. Some browsing reveals this:
All manifolds are homotopy equivalent to a CW complex [--interestingly, there is kind of an inverse too: all countable CW complexes of dim n are homotopy equivalent to a differentiable manifold of dimension 2n+1 http://miami.uni-muenster.de/servlet...m_vol_3_01.pdf ] All smooth manifolds have a CW structure Not all manifolds are triangulable (e.g. the E8 manifold) Whether or not all manifolds have CW structure, I think is an open problem, although I'm having difficulties looking this one up. It seems we were basically correct about a punctured n-manifold being htpy equivalent to an n-1 complex, this gives an affirmative answer in the smooth case: http://mathoverflow.net/questions/18454 |
| Jun12-12, 07:15 AM | #20 |
Recognitions:
BTW: In the smooth case, what happens with the gradient flow of an arbitrary Morse function? Puncture the manifold at a relative minimum and follow the flow from there. Let's make up some examples. |
| Jun12-12, 10:44 AM | #21 |
I'm thinking of a torus - how does the flow continue past the first critical point?
| Jun12-12, 10:41 PM | #22 |
Recognitions:
BTW: The cut locus can not contain an open set since an interior point would be reached by a geodesic that minimizes length until it reaches the point |
| Jun15-12, 10:53 AM | #23 |
Recognitions:
| Jun17-12, 02:02 PM | #24 |
So it's the gradient flow just "going upwards" but multiplied by a scalar?
Just drew a picture, and I think I see how it goes, you at least get to a very small retract of the figure 8. |
| New Reply |
| Thread Tools | |
Similar Threads for: deformation retraction of plane RP2
| Thread | Forum | Replies | ||
| retraction in surface of genus g | Calculus & Beyond Homework | 1 | ||
| Projective planes and retraction | Calculus & Beyond Homework | 0 | ||
| Scapula retraction and protraction | Medical Sciences | 6 | ||
| Retraction/reflection help please | Introductory Physics Homework | 9 | ||
| Retraction math help | Linear & Abstract Algebra | 32 | ||
