New Reply
Heat required to evaporate water.
Share Thread
Jun13-12, 11:06 AM   #1
If 1 kg water is required to be evaporated, not at 100 degree Celsius, how can I calculate the heat required.
Let say a constant temperature of 50 degree Celsius is maintained, then what will be the scenario, and what if the constant temperature of 70 degree Celsius is maintained.
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Jun13-12, 12:03 PM   #2
Usually, when calculating the heat required, use the heat transfer equation:
Q= mcΔt
Q=energy, or heat
m=mass
c=specific heat capacity
delta t= change in time
Jun13-12, 01:33 PM   #3
Quote by makovx View Post
Q= mcΔt
Q=energy, or heat
m=mass
Delta T, in my understanding is the change in temperature.
And this equation is for calculating heat required to raise the temperature by certain degree Celsius of the given material.
I want to keep the temperature constant, that is, supplying the heat through a constant temperature air.
I wonder that will the heat required will be equal to the latent heat of vaporization of water (as it is on 100 degree Celsius), or should there be any difference.
Jun14-12, 07:46 PM   #4
You do not have access to steam tales or a psychrometric chart or a Mollier diagram to determine the enthalpy change from liquid water to vapour at a set temperature?
Jun15-12, 09:52 PM   #5
See 3rd and 2nd from last columns in this table: http://www.engineeringtoolbox.com/sa...ies-d_457.html for latent heat from about 20 degrees C to 230 degrees C.
New Reply
Similar discussions for: Heat required to evaporate water.
Thread Forum Replies
Heat power needed to partially evaporate water from a water container Introductory Physics Homework 1
Specific & Latent Heat - Heat required to turn water in Aluminum Tray --> Ice Introductory Physics Homework 9
Termochem problem. Work required to heat water Biology, Chemistry & Other Homework 1
Amount of energy required to evaporate 1 liter if water through scheffler dish Engineering Systems & Design 3
Heat needed to evaporate water Advanced Physics Homework 2
