Stoichiometry to find concentration and pH
The discussion revolves around a homework problem involving the calculation of concentration and pH of a solution formed by the dissociation of calcium hydroxide in water. Participants explore the dissociation equation, the concentration of hydroxide ions, and the calculation of pH, addressing both theoretical and practical aspects of stoichiometry.
  • Homework-related
  • One participant presents the dissociation equation for calcium hydroxide and calculates the moles of Ca(OH)2 based on its molar mass and the given mass.
  • There is a question about whether to use 0.855 L for volume in concentration calculations, with some confusion regarding the unit (mL vs L).
  • Participants discuss the relationship between pH and pOH, suggesting that to find pH, one should first calculate pOH from the concentration of hydroxide ions.
  • Another participant emphasizes the importance of significant figures in calculations, providing a detailed breakdown of how to arrive at the correct concentration and pH values.
  • There is a correction regarding the initial misunderstanding of the volume, with one participant acknowledging their error in interpreting the volume as mL instead of L.
Participants generally agree on the dissociation equation and the method for calculating concentration, but there is some disagreement and confusion regarding the correct volume to use and how to properly calculate pH from hydroxide concentration. The discussion remains unresolved on the final pH calculation due to differing approaches and interpretations of significant figures.
Limitations include potential misunderstandings about the volume unit (mL vs L) and the implications of significant figures on the final results. There is also uncertainty about the relationship between hydroxide and hydrogen ion concentrations in the context of pH calculations.
pleace
15.1g of calcium hydroxide completely dissociates in distilled water forming 855ml of basic
solution.
a) Dissociation Equation
b) Calculate the concentration of OH in the solution
c)Calculate the pH of the above solution
c=n/v
pH=-log[H]
a) Ca(OH)2 (s) = Ca2+ + 2OH -
i think that equation is right?
b) using molar mass ofCa(OH)2 and 15.1g, the moles of Ca(OH)2 is around 0.2moles.
since Ca(OH)2 and OH are in 1:2 ratio, then there is 0.4 moles Oh.
c=n/v
c=0.4/0.855 =0.452 mol/L(DO i use 0.855L for the volume even tho that includes the entire basic solution which is Ca2+ + 2OH - ?)
c) Now this is the part where i am really unsure about.
pH = -log[H], but since i want to find the entire solution's pH, what concentration do u use? do i divide 0.452/2=0.226
and then go -log0.226 = 0.64.
Thank you so much if you try to help me :)
The volume is 0.855 mL as per the question. Are you sure it's 0.855 mL in the question? I seem to get some weird answers if i use 0.855 mL. But, i will check out again.
We do not have the concentration of H+. Do you know any relation between p[H] and p[OH]? :wink:
i meant to put [OH] i forgot to type the O. and yes i am 100% sure that it says 855ml
Hi pleace! :smile:
No, you are halving the actual concentration that way...you need to pH of the solution which is defined to be the concentration of H+ in the solution. So use it to find pOH and then convert it to pH.
I misread the question, its 855 mL and i am seeing it as 0.855 mL, i am such a dumb. :-p
Anyways, back to question, do you know about the relation: p(OH)+p(H)=14?
Find pOH and use the relation to find pH.
solution.
c=n/v
pH=-log[H]
c=n/v
A is right, and B is right too. Concentration should be measured in molarity which you correctly represented as moles/liters. But don't round your sig figs so early, this could be bad.
1. Calculate the molar mass: this is about 74.0932 g/mol.
2. Multiply that by your 15.1 grams to get 0.2037973 mol.
3. Multiply that by two to get 0.4075946 mol.
4. Divide by .855 L to get a 0.476719 M solution of hydroxide OH- ions. But to get the right answer for C, you must take into account that we only have 3 sig figs, so the concentration would be 0.477 M.
5. Employ the rule pH + pOH = 14. In other words, pH = 14 - pOH. pOH = -log[OH-]. Our concentration is 0.476719 M, so we just take the negative log of that. -log[0.476719] = 0.740828. Therefore, pH = 14 - 0.740828 = 13.259172.
6. LAST STEP: Sig figs. The equation you gave us has two numbers: 855mL, and 15.1g. They both contain three sig figs. But when we use logs, the only sig figs are the ones to the right of the decimal. So 13.259172 pH becomes 13.259 pH.
EDIT:
This is why sig figs are so important. If we used your numbers, we would get a concentration of about 0.452 M, the total pH would be 13.655 instead of 13.259. That's about 0.396 off.
  • · Replies 22 ·
