| New Reply |
Motion 2 problems -- Tossing hay bales and baseballs |
Share Thread | Thread Tools |
| Jun20-12, 06:04 PM | #1 |
1. The problem statement, all variables and given/known data
1. A hay-baling machine throws each finished bundle of hay 2.0 m up in the air so it can land on a trailer waiting 4.7 m behind the machine. (a) What must be the speed with which the bundles are launched? 2. A baseball is popped up, remaining aloft for 6.3 s before being caught at a horizontal distance of 83 m from the starting point. What was the launch angle? 2. Relevant equations 1. x = 1/2at^2 +vot +x0 x-xo = d 2. vx = cos*vo vy = sin*vo 3. The attempt at a solution 1. I used the distance and plugged it into the first equation but it is the wrong answer I believe. 2. I know that in the end I have to divdide vy by vx and take the arctan of that but I do not understand how to find vy and vx. Can someone explain to me step by and step and what that means? |
| Jun20-12, 09:17 PM | #2 |
Can you form an equation now? |
| Jun22-12, 06:59 PM | #3 |
This is going to sound like weird advice, but you're not thinking about the problem right. Don't think "I know that in the end I have to..." Just work through it.
Your equations are sound. Lets start with this: you know the maximum height right? What can you find with that if you know the acceleration of gravity? |
| Jun22-12, 07:17 PM | #4 |
Motion 2 problems -- Tossing hay bales and baseballs1. Identify a) Only one object - the hay bale b) The object doing 2 works. Going in horizontal and verical motion. 2. Select y=y0+vy0ty+(1/2)ayty2 x=x0+vx0tx+(1/2)axtx2 Since it involves only one object, ty=tx 3. Execute 4. Evaluate |
| New Reply |
| Tags |
| motion |
| Thread Tools | |
Similar Threads for: Motion 2 problems -- Tossing hay bales and baseballs
| Thread | Forum | Replies | ||
| Probability - Tossing a coin, counting X heads, then tossing X more times. | Calculus & Beyond Homework | 6 | ||
| Projectile Motion problems (don't want answers to problems) | Calculus & Beyond Homework | 1 | ||
| Influence of a humidor on the aerodynamics of baseballs | General Discussion | 5 | ||
| [SOLVED] baseballs and impulses | Introductory Physics Homework | 2 | ||
| fair die tossing problems | Set Theory, Logic, Probability, Statistics | 6 | ||
