Does It Matter Which Vector You Start With When Using the Parallelogram Rule?
  • Thread starter Thread starter mpaige1
    Parallelogram
The discussion revolves around determining the resultant force of two vectors, P and Q, using the parallelogram rule. The vectors have specified magnitudes and angles relative to a reference plane, which some participants question as potentially implying a three-dimensional context.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore different methods of applying the parallelogram rule, questioning whether the order of vectors affects the resultant. Some participants express confusion over the angles used in calculations and the implications of dimensionality in the problem setup.
There is an ongoing examination of the calculations and assumptions made regarding the angles between the vectors. Some participants have provided insights into the properties of the parallelogram rule, while others have identified discrepancies in the calculations presented. The discussion remains open with no clear consensus reached.
Participants note the potential for confusion regarding the reference plane versus a reference line, as well as the implications of using different angles in the cosine law calculations. There is acknowledgment of a diagram intended to clarify the problem setup, though its visibility is uncertain.
mpaige1
Determine resultanat force of vectors P (40N) and Q (60N). P is 20 degrees from reference plane and Q is 45 degrees from reference plane.
When using the parallelogram rule, should you always start with the lowest angle vector? (like in the bottom diagram of the attached image)
I solved the question using the parallelogram in two different ways and ended up with different answers. Is there a right way to do this?
Solution 1:
P vector, then Q vector with resultant vector starting at tail of P to tip of Q.
Law of Cosines yields,
R = 97.726N
Law of Sines yields,
Angle A = ∠15.039
alpha = ∠20 + ∠15.039 = ∠35.04
Solution 2:
Q vector, then P vector with resultant vector starting at tail of Q to tip of P.
R = 98.542N
A = ∠7.9803
alpha = ∠45 - ∠7.9803 = ∠37
Diagram attached.
You say "reference plane" which implies three dimensions. But in that case, there are an infinite numbers of candidates for P and an infinite number of candidates for Q. I will assume this is a two dimensional problem and you mean "reference line".
Do you understand why it is called the "parallelogram" rule? A parallelogram has four sides, two of which represent P and two which reresent Q- it doesn't matter which you "start with".
Solution 1:
R = 97.726N
It's impossible to say what you might have done if you don't say what you have done! Here, you have a triangle with two sides of lengths 40 and 60 and angle between them of 140 degrees. Applying the cosine law I do NOT get 97.726.
Angle A = ∠15.039
Solution 2:
R = 98.542N
A = ∠7.9803
Diagram attached.
All I can say is I get a completely different answer. I can't say what you are doing wrong. I presume you know that the cosine law says that [itex]c^2= a^2+ b^2- 2abcos(C)[/itex]. The fact that that is "symmetric" in a and b should tell you that it doesn't matter which side you call "a" and which side you call "b". What angle do you have between the two vectors?
Sorry, I used the wrong value for the angle in cosine. It should have been 155 and I used 160. This should be correct, the textbook I'm working from has the same as their answer. It could be wrong but I doubt it.
Here's the complete walkthrough of the problem:
R^2=〖60〗^2+〖40〗^2-2*40*60cos(155)
R = 97.726N
sin(A)/40 = sin(155)/97.726
A = 9.9612
alpha = 35.039
I'm not sure if the diagram I gave is showing up but it should have everything you need on there. No worries guys, it was a stupid mistake.
14K
  • · Replies 175 ·
29K
