| New Reply |
Flow Separation of Airfoil in terms of Reynolds Number |
Share Thread | Thread Tools |
| Jun27-12, 12:02 PM | #18 |
The different sized wakes in different fluids may be attributed to differences in viscosity, though I cannot be certain unless you provide the name/link to the paper. In general, a higher viscosity in the flow will correspond to higher diffusion rates and a quicker dissipation of the wake. Again, this goes back to the debate on how turbulence levels affect the flow/separation. If there is a specific concept or question that you have regarding the papers you have read feel free to ask.
| Jun27-12, 02:21 PM | #19 |
As long as the Reynolds numbers are the same, the fluid shouldn't matter for the size of the wake so long as it is incompressible regardless of the viscosity. If the viscosity is higher for one, just increase the speed or size of the model a little bit. |
| Jun27-12, 03:05 PM | #20 |
Actually you made me realize that if the viscosities are the same and the reynolds numbers are constant then differences in mach number may affect the wake. However neither of us have the paper to make a firm statement.
| Jun27-12, 04:11 PM | #21 |
I was actually not referring to a paper, but this video: http://vimeo.com/7507698 An experiment was done for two objects (one streamlined, one spherical) traveling in air(around 15:00) and glycerin (around 19:00). The streamlined object traveled slower than the spherical in glycerin for the same drag force applied (also I could not see the wake for either object) which wasn't the case when air was used. Speed was decreased and viscosity increased in the glycerin, so the Re must be extremely low. From pictures of separation in air for a sphere, I can see that there's usually quite a large wake. I'm not sure if separation was actually occurring at the same location but the glycerin simply dissipated the effects or something else altogether. Thanks very much |
| Jun27-12, 05:28 PM | #22 |
Given the speeds and Reynolds numbers involved, that teardrop shape is certainly not separated at all and I would actually contend that even the sphere likely is not separated, as it appears that the experiment satisfies the requirements for Stokes flow. It has no wake and therefore effectively has only viscous drag. As a result, you have one shape with small surface area and one with large surface area, both dominated by viscous drag. Of course the one with large surface area (the teardrop) will move more slowly. In the air, the Reynolds number is going to be much, much larger and while the teardrop will still be dominated by viscous drag, the sphere will be dominated by pressure drag. In these situations, pressure drag is dominant and so the sphere had higher drag in the air flow.
At the kind of low Reynolds numbers ([itex]\mathrm{Re} \ll 1[/itex]) seen in the glycerine experiment, there certainly is an effect due to Reynolds number. You have to remember what the Reynolds number represents. Recall the definition [tex]\mathrm{Re} = \frac{\rho U_{\infty} D}{\mu}[/tex] The number represents a ratio of the inertial forces due to the fluid motion to the viscous forces. For the extremely low Reynolds number, the viscous forces are dominant. For most practical flows such as on cars, planes, etc., the Reynolds number typically falls more within the range [itex]10^3 \leq \mathrm{Re} \leq 10^7[/itex]. Anywhere in that range, the inertial forces are many orders of magnitude more important than viscous forces. The behavior when [itex]\mathrm{Re} \ll 1[/itex] and [itex]10^3 \leq \mathrm{Re} \leq 10^7[/itex] are fundamentally different in essentially all regards. However, within one range or the other, the fluid behaves fundamentally the same regardless of where you fall in that range. |
| Jun28-12, 03:07 PM | #23 |
Last night I happened to be looking through my aircraft design book and came across an excerpt that is very pertinent to the discussion of this thread. The Book is "Aircraft Design: A Conceptual Approach 4th Edition" from page 306, the paragraphs (truncated) read:
And one more thing I wanted to ask/add with regards to the notion that a fluid behaves essentially the same when E3≤Re≤E7: |
| Jun28-12, 04:37 PM | #24 |
Otherwise, there is no generic Reynolds number where the flow is assumed laminar or turbulent. The problem is extraordinarily more complicated than that. We don't even have a general model for the transition location on a zero-pressure-gradient flat plate at zero angle of attack as a function of Reynolds number, let alone an airfoil. |
| Jul2-12, 05:06 PM | #25 |
Sorry for the late response, it was a busy weekend. Anyway, when I was speaking about the Reynolds number ranges I was coming from a historical perspective. Many papers cite those ranges typical to the aircraft mentioned above.
I cant say I know much about Görtler vortices or a lot of details about turbulence/turbulence modeling as I have not taken any classes on the material yet. However, in lieu of these facts I will proceed to read some more papers on the subject. |
| Jul2-12, 06:29 PM | #26 |
If you truly are interested in the subject though, then here are the three sources I mentioned. http://www.dtic.mil/cgi-bin/GetTRDoc...f&AD=ADA147243 (Mack 1984, ch. 3 is on linear stability theory, long read) http://www.annualreviews.org/doi/abs....101101.161045 (Saric 2003) http://www.annualreviews.org/doi/abs....010194.002115 (Saric 1994) |
| Jul10-12, 02:28 PM | #27 |
Thanks ill look into those. One thing im really interested in is a statistical mechanical description of fluid flow and turbulence.
| Jul10-12, 03:24 PM | #28 |
Ha. Can't help you there. I am not personally a fan of the statistical approach to fluid mechanics (turbulence modeling, etc.). Count me among the camp that believes that if we had powerful and accurate enough computers, it would be a form of spatio-temporal chaos: crazy but still deterministic.
It's certainly a useful field, but not my thing. |
| Aug2-12, 12:32 AM | #29 |
My apologies for the late response. So essentially flow separation location would be the same in whatever range is considered (i.e. for Re between 10 and 100 it wouldn't change, but would be different than Re 10^3 to 10^7)? So for the same "level of turbulence", I can have Re at whatever I want without affecting the separation location? Lastly, I'm wondering how come Cf and Cp varies with Re if the size of the wake is unchanged? Thanks very much |
| Aug2-12, 11:42 AM | #30 |
Boneh3ad mentioned that the flows in this range are fundamentally the same which is true. They are both dominated by inertial forces but that does not mean the details of the flow are the same. |
| Aug8-12, 09:07 PM | #31 |
Am I correct in saying that one can see separation point changing with Re in real life but such an effect is not due to the change in Re but other changes that are typically associated with flows as Re increases (assuming flow is in the laminar region), thus there is actually no theoretical relationship but only a correlative effect? Also, in the instance you described, is there a "typical" direction in which flow separation point moves? Thanks very much |
| Oct22-12, 03:14 AM | #32 |
Hey guys I have a questions on the Reynolds number and you seem to be pros on the subject could you help me out.
http://www.physicsforums.com/showthr...78#post4126078 Thanks! |
| New Reply |
| Thread Tools | |
Similar Threads for: Flow Separation of Airfoil in terms of Reynolds Number
| Thread | Forum | Replies | ||
| Reynolds number for case flow over airfoil | Aerospace Engineering | 3 | ||
| flow coefficient and reynolds number | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Small Reynolds Number Flow around Flat Plate | Mechanical Engineering | 2 | ||
| Effect of reynolds number on flow in wave tank | General Physics | 0 | ||
| change in flow / velocity direction and the Reynolds number | General Physics | 0 | ||
