New Reply
Is there a general method to aproximate functions with ratios of polynomies??
Share Thread Thread Tools
Jun27-12, 10:52 AM   #1
Hi All,
There is a variety of methods to approximate functions (Taylor expansions, Fourier series, Splines, Interpolation, ... ) yet, when it comes to approximate some statistical distributions none of these methods seems to be as computationally efficient and accurate as using ratios of polynomials. I know of several of these ratios in the literature to approximate Gaussian distributions, but what I fail to find is a general method to adjust any arbitrary function to ratios of polynomials.
So, do you happen to know if there is a general method to find the ratio of polynomials that better fits a function?
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun27-12, 10:58 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
"Ratios of polynomials" are called "rational functions". Googling "approximation" with "rational functions" gives a number of hits including
http://en.wikipedia.org/wiki/Rational_function
http://www.measurement.sk/PAPERS/Bartkov.pdf
http://www.ams.org/journals/tran/193...-1501629-1.pdf
and references to books on the subject:
http://books.google.com/books/about/...d=f93ubGXa7bgC
Jun27-12, 01:45 PM   #3
Quote by HallsofIvy View Post
Hi HallsofIvy,
Thank you for the links,
The first paper shows a general method but is misses the point of the procedure since it first approximates the function with a polynomial so, in cases where this approximation is not good, the cases where we would actually want to use rational functions, the rational function will not be a good approximation either.
The second paper is more theoretical and goes on in properties and no so much in general procedures to approximate any arbitrary function.
The third link, the book, I didn't buy it, but I had the chance to have a look and the lectures titles and one of them is "Rational Approximation to [itex]e^x[/itex]" which makes me think that the state of the art of approximating arbitrary functions with rationals functions is a per case problem... Hence why I made this question.
Jun27-12, 08:07 PM   #4
Recognitions:
Homework Helper Homework Help
Is this what you're looking for?:
http://en.wikipedia.org/wiki/Pad%C3%A9_approximant
Jun27-12, 09:04 PM   #5
Math 2012
Recognitions:
Quote by viraltux View Post
I haven't read the paper, but your statement is missing the point that the approximations might be of different orders.
For example, if you approximate a function by a Taylor series, you may need a large number of terms to get high accuracy, but the largest errors often occur only at the ends of the interval, and the accuracy near the center is much higher than you need. If the highest term in the approxmation in this approximation ##P_n(x)## is ##x^n##, you can then approximate the ##x^n## term by a Chebyshev polynomial of order ##n-1## and get a new approximation ##P_{n-1}(x)## with a lower order. Often the maximum error of ##P_{n-1}## is no worse than ##P_n##, but the errors are spread more evenly accross the whole range. Sometimes you can repeat this several times to get a good approximation with a much lower order than ##n##.
The same idea should apply to converting a polynomial approximation to a rational polynomial approximation.
Jun27-12, 09:47 PM   #6
You mentioned fourier series, but the whole area of fourier analysis is great if you want to find a good enough functional approximation for approximating a given function within an interval.
What you could do is to create a template rational function P(x)/Q(x) and create an orthonormal subspace and project your function or data to this new rational function.
You may have to derive this yourself using the fourier analysis framework ideas and Gram-Schmidt process, but I recommend you check it out.
Examples of orthogonal polynomials and related include Bessel, Legendre, and Hermite just to name a few.
Jun28-12, 02:23 AM   #7
Quote by Mute View Post
Oh! WOW!! it certainly looks so, first time I hear about the Padé approximant! Thank you Mute!!
Quote by AlephZero View Post
Well, of course, I didn't mean that he paper has no application in any case, I wouldn't be surprised if there are problems where is the right approach, but definitely not the general method I was asking for.
Quote by chiro View Post
It seems this must be one approach since the book link offered by HallsofIvy suggests in its index the use of Hermite Polynomials, so yours was a great insight. I wonder though how it plays against the Padé approximant. Anyway, more interesting stuff to check, thanks!
Thank you all guys for the feedback, it was very helpful!!
New Reply
Tags
fourier, spline, taylor
Thread Tools
Similar Threads for: Is there a general method to aproximate functions with ratios of polynomies??
Thread Forum Replies
What other functions can be used to aproximate Poisson's distribution? Set Theory, Logic, Probability, Statistics 1
Aproximate ground state wave functions Advanced Physics Homework 6
Products and ratios Bessel functions -> any known approximations? Calculus 1
Aproximate Sin() General Math 10
The Function Pi(x) formula...(aproximate) General Math 1
