| New Reply |
Fukushima - Why did Unit 2 release so much more radioactivity than Units 1 and 3? |
Share Thread | Thread Tools |
| Apr10-12, 08:20 PM | #154 |
Thanks to tsutsuji for providing this paper:
http://sciences.blogs.liberation.fr/...hima-1-an-.pdf On page 46, there's a table where IRSN lists its release estimates. For Cs-137: Unit 1 1 PBq, Unit 2 6 PBq, Unit 3 14 PBq. The NISA estimate which makes Unit 2 responsible for 90% of the release is right below it, so IRSN has to be aware that the japanese think otherwise. Perhaps they are explaining why somewhere in the text...? Unfortunately, I don't understand a single word french... |
| Apr10-12, 10:01 PM | #155 |
However, it is possible to infer that because the winds were onshore while #2 was emitting, shifting to offshore when #3 was the focus ( discussion on p50), reactor 2 was responsible for most of the land pollution damage. The estimates given in Science were for the total site emission, yet even those cover a factor of 3 range, so much better estimates will be laborious to obtain. |
| Apr19-12, 02:52 PM | #156 |
From the recent torus room survey, the radioactivity of the room is very high everywhere, but particularly so in two of the surveyed areas, one area at the door entry level to the NE corner of the torus room, and another at the inspection level at the NW corner.
The simplest explanations I can think of are, respectively, that the door entry level is just closer to the surface of the accumulated highly radioactive water below, while the hotspot in the NW corner could be because there's a leak to the torus room from the PCV, somewhere above the waterline of the torus room, either a leak from the torus, or directly from the PCV. Also interesting is that we see some damage to insulation around pipes several places, the shape of which seems to indicate they've been exposed to some low key event of internal overpressure, or external vacuum, relative to the insulation capping of those pipes. But really nothing serious of an explosive nature seems to have happened in the room. |
| May6-12, 09:20 AM | #157 |
Unless interesting new information emerges, for now I am going to stick with the conclusion that reactor 2 released more radioactive substances because of a failure to wet-vent.
On page 152 of Tepco's interim report, they manage to make this point without actually drawing attention to high releases from reactor 2: http://www.tepco.co.jp/en/press/corp.../111202e14.pdf |
| May7-12, 12:35 AM | #158 |
| May7-12, 09:57 AM | #159 |
I won't be repeating all of that since I posted so much in this thread already. I have acknowledged that it is possible to underestimate the release from reactor 3 due initially to wind direction, and then because it could have got mixed up with events occurring at reactor 2.
So no, I cannot be absolutely sure that reactor 2 released much more than reactor 3. We have a range of reasons why it might of, some of which I found quite compelling. Given the timing of the melt, failure to vent, pressure the containment was under and likely contents of its atmosphere when it started to leak in a vigorous fashion, I have no trouble with this conclusion, although Im always ready to change it or learn more if the chance presents itself. One way which we may further explore the differences between reactor 2 & 3 is by looking at the timing of the release of substances from the fuel, and the timing of vents. If we would expect the bulk of the substances to enter the atmosphere of containment during the main initial fuel melting, then scrubbing that via a wet vent before containment leaks in a major way should make quite a large difference to how much stuff enters the environment. This is not a subject I have expert knowledge in so I would like to know more about the timing of releases from fuel. |
| May7-12, 03:45 PM | #160 |
| May25-12, 12:42 PM | #161 |
However at the time of writing it is only available in Japanese, and computer translation of this document in particular gave quite horrible results in many places. So I really need to wait for better translation before discussing any of these details further. http://www.tepco.co.jp/cc/press/betu...20524j0105.pdf |
| May27-12, 12:37 PM | #162 |
OK I've had to make do with machine translation because it doesn't sound very likely that TEPCO will be translating the full document, only the shorter ones.
I will talk on the main thread about the report as a whole as it obviously deals with all reactors, but from what I think I've been able to make sense of in relation to reactor 2: Even though they are unsure whether the vent took place, they seem to be focussing far more on the March 14th wet vent attempt, rather than the very brief dry vent attempt just after midnight on the 15th. Probably because of ability to speculate a link between increased site dose rates and the wet vent attempt, quite a large amount of emissions are pencilled in as occurring during this time and coming from reactor 2 (see table on page 9). That table is interesting for many other reasons also, including the fact that these figures are probably more in line with some peoples expectations in terms of which reactors are to blame for radioactive release - reactor 3 (and to a lesser degree reactor 1) gets a much larger share of the blame in this table, reactor 2 totals are still rather large but don't make other reactors irrelevant by comparison. When they talk of soil contamination, March 15th reactor 2 emissions are the main focus for reasons we already discussed before. They have various diagrams showing wind direction and presumed plume path during variety of different venting operations, and they have the rain radar images from late on the 15th to the north west. In regards to non-vent leaks, they talk about such matter quite a bit. They acknowledge steam escape from top of containment. Here is the original Japanese for a key part of the detail on this as it pertains to reactor 2: 1.3.2 2 号機原子炉直上部からの蒸気確認 平成 23 年 9 月 17 日に、2 号機 R/B のブローアウトパネル開口部からダストサ ンプリングを実施した際に動画を撮影したところ、原子炉直上部から蒸気発生が 確認された(別図 3)。具体的に蒸気がどこから漏えいしているのか現時点では確 認出来ていないが、動画映像から蒸気の漏えい箇所としては原子炉の上部に位置 する PCV トップヘッドフランジ上部の原子炉ウェル上蓋付近からであると推定さ れる。また、使用済燃料プールの温度が高くない(平成 23 年 9 月 17 日時点で約 34°C)ことから、確認された蒸気は PCV から漏えいしてきたものであると考えら れる。PCV トップヘッドフランジ(及び原子炉ウェル上蓋)の構造は 1 号機、3 号機とも 2 号機と同様であり、1・3 号機でも 2 号機と同じ PCV 漏えいパスが存 在している可能性が考えられる。 さらに、現在判明しているR/B内の空間線量測定結果によると、R/B5階で確認 された高線量(約200mSv/h)は、4階以下では確認されていない(別図4)。2号機 はR/B構造が維持されており、線量の分布と漏えい経路には相関性があると考えら れることを踏まえると、5階からの漏えいが主たるものであったことを示唆してい る。 |
| May28-12, 04:40 AM | #163 |
As regards the peak in the evening of March 14th, using Google Translate, I glean from the note that Tepco is assuming it came from exhaust stack 1+2, because the emission point is unknown. If that is the evidential standard, I am pretty sure I can mount better evidence for the proposition. that the March 14th evening peak was due to emissions from unit 3. |
| May28-12, 10:17 AM | #164 |
old jim |
| Jul1-12, 03:03 PM | #165 |
Lot of discussion is going on why maximaum radioactive material was released from unit 2 of Fukushima. Pirma facie it looks surprising even unbelivable as unit 2 building is least damaged, no hydrogen explosion took place in unit 2, its cooling system (RCIC) lasted for 70 hrs after the earthquake, core damage started later as compared to other units and no venting was done from unit 2 containment. Then why more radioactive material got released from unit 2 than oter units. Answer of this is very simple, that is, because no venting was done or could not be done from unit 2 containment.
As no venting could be done from unit 2, its containment got pressurised and it failed due to overpressure. Venting could not be done as rupture disc in hardened vent header did not rupture. Containment failure took place at weakest links such as penetrations, seals and gaskets. Activity released from drywell through these leaky points and came into reactor building. From reactor building it came into atmosphere through blowout panel of reactor building which had got opened during unit 1 hydrogen explosion on 12th March. Since release was from drywell, it was unfiltered release and that too it was ground level release. It is a case of 'suppression pool bypass'.Because of failure of containment penetrations, water injected for core cooling came into turbine building through pipe trenches/cable trenches and it contributed in release through water route. In contrast, containment venting could be done in unit 1 and unit 3. This venting was done from suppression pool air space. Radioactive material coming to suppression air space has to pass through suppression pool water. During this passage much of the radioactivity (around 99%) is filtered out. Water acts as filter in this case, since most of the volatile fission products like cesium, iodine, telerrium get dissolved in it and particulates get suspended in it. Remaing 1% contains mostly noble gases which get dispersed in atmosphere, do not dissolve in water/rain and thus do not fall out on the ground. One line answer to the question why maximum radioactivity was released in atmosphere from unit 2 is that "Activity released from unit 2 was mostly unfiltered while from unit 1 &3 it was mostly filtered." |
| Jul2-12, 03:33 AM | #166 |
| Jul2-12, 02:34 PM | #167 |
Sharma sk |
| Jul3-12, 02:49 AM | #168 |
| Jul3-12, 03:15 AM | #169 |
Point is, without extensive information that would allow us to piece together something close to the real accident sequence, we can't really tell. Speculation is (VERY uncharacteristically for this forum) allowed by the mods in the Fukushima technical threads. But, it should be clearly understood as such. |
| Jul5-12, 01:51 PM | #170 |
I think this particular stuff goes beyond the usual unsubstantiated speculation though. Yes there are many questions remaining, but those who are not very keen on the idea that reactor 2 released more into the environment than the others might want to investigate the following sort of thing further:
Given that the failure to wet-vent at an important moment is key to this theory, can't someone look into details about when the most significant amounts of radioactive material is expected to be present in the atmosphere and steam from containment? Because left to a common-sense rather than proper scientific view of this issue, I certainly don't have any trouble believing that the time during and immediately after the core is completely exposed is a rather crucial one. And at reactors 1 & 3 we had wet-venting operations conducted in the aftermath of the core uncovering, and before we saw evidence of steam rising from upper containment failures. The other factor is the pressure of containment at the time of failure & mass ejection of steam etc. These are the reasons I am not going to reject the hypothesis that reactor 2 had far more significant environmental implications, although as discussed in the past this is complicated by the fact that weather factors meant any releases from reactor 2 were far more likely to have an impact on Japanese land. |
| New Reply |
| Thread Tools | |
Similar Threads for: Fukushima - Why did Unit 2 release so much more radioactivity than Units 1 and 3?
| Thread | Forum | Replies | ||
| How will they end the Fukushima disaster? | Nuclear Engineering | 38 | ||
| total fukushima I-131 release vs chernobyl, in curies | Nuclear Engineering | 22 | ||
| Instantaneous Unit Conversion between CGS and SI units | General Math | 2 | ||
| Maxwell related equations converted from MKSA units to Gaussian units | Classical Physics | 2 | ||
