| Thread Closed |
Soap phenomenon |
Share Thread | Thread Tools |
| Mar23-03, 12:52 PM | #1 |
Soap phenomenon
To know what I'm talking about you'll have to do a little experiment....
Go to your bathroom, take some soap and foam up your hands. Make a "bubble" with your index finger and your thumb, then reflect the light from a lamp in the "bubble". After a little while oil-like rainbowcolored patterns will appear. In the beginning, make sure you don't breath or blow on the bubble. In the oil-pattern you should see particle-shapes in various sizes traveling from one side to the other (or to the center). A few might shoot by in a random direction with high speed. HOW do these shapes form ? where do they come from [?] ... To me the whole thing looks sort of like a bubblechamber where particles enter and leave traces, except these particles would be enormous ! [:)] When the bubble is filled with colors and particle-shapes, try blowing VERY gently on it. What happens is that the patterns start freaking out ! [:D] .. They twist and turn very fast in seemingly random directions ! Could someone please explain why this happens ? .. I can't see how such weak air turbulence could cause movement like that in the soap. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Mar23-03, 01:05 PM | #2 |
You've just constructed a basic interferometer!
What happens is that the thickness of the soap film determines which wavelengths of light will interfere constructively and which destructively; and hence which colors you see reflected. Very small changes in the thickness of the film -- a few hundred nanometers -- will cause a change in colors. So it's very sensitive; the patterns you see at the beginning are probably due to the bubble slowly thinning or flattening under its own weight or very slight air currents. This effect, interferometry, is widely used to make precision measurements. |
| Mar23-03, 01:11 PM | #3 |
My enquiry was not about the colors, but the patterns & movement that arise in the colors. I don't believe aircurrents explain the particle-shapes that show up.
I suggest you do the "experiment" so you'll see what I'm talking about [:)]. |
| Mar23-03, 01:14 PM | #4 |
Soap phenomenon
hehe we were just learning about thin film interference in class this past week!
What I guess happens is the bubble isnt uniformly the same thickness....so as the soap kinda swirls around the bubble (affected by outside forces like gravity and the air) the thickness changes slightly at various points, causing destrictuve/constructive to occur at various points.. Again, this is just a hypothesis..but it sounds right. |
| Mar23-03, 01:25 PM | #5 |
do the experiment then read my first post again. I'm not wondering about the interference.
| Mar23-03, 03:15 PM | #6 |
Hydr0matic, I just tried to reproduce your results. OK, I saw the 'particles': hundreds of them. They appeared white on a backgound of rainbow colors. They didn't move much, but if they did, then mostly downwards. They became less over a period of some seconds. Then, as almost all 'particles' had vanished, I blew on the film. Rainbow colors went turbulent.
My interpretation: The particles are little bubbles of air enclosed in the water film. They can't (as an air bubble would in a liquid) move upwards. That's because, via surface tension & hydrogen bonds, part of the mass of water surrounding a bubble is attracted to the bubble, so it forms a massive object inside the water film. Which tends to move down. Blowing on the film, of course, causes air turbulence. Which induces the film to form erratic variations in thickness, making the rainbow colors go gaga. |
| Mar23-03, 05:33 PM | #7 |
1. How do you explain what I mensioned above ? 2. Some of the "particles" emerge in the middle of the bubble, why ? Perhaps I'm making too big 'a deal out of this [:D] [;)] |
| Mar24-03, 03:47 AM | #8 |
Surface Tension!
Quantum Catastrophe! Do a search for surface Tension (and) Critical Points, failing that go do a search for Ulf Leonhardt, he is the one who is trying to create 'table top blackholes', using a 'orthoscopic cavity', or for the layman, bubble traps. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Soap phenomenon
| Thread | Forum | Replies | ||
| Antibacterial Soap No Better And May Be Worse Than Plain Soap | General Discussion | 30 | ||
| Antibacterial soap | Biology | 3 | ||
| Cut a bar of soap in1/2 | General Discussion | 18 | ||
| Soap Bubbles! | General Physics | 3 | ||
| Bar of soap | Introductory Physics Homework | 5 | ||
