New Reply
Determine the gas if the pressure of its saturated steam is known
Share Thread Thread Tools
Jul7-12, 06:31 AM   #1
One hundred thousands denarii (or 423 kg of gold) cost a vase from mineral A in Ancient Rome. A Painter in 17th century occasionally got from it gas B and Physicist in 19th told an assumption of its composition.
There are experimental data of pressure of its saturated steam and density over a liquid at different temperatures:
T, oC 0 20 40 60 80 100
p, mm m.c. 363,8 773,2 1516 2778 4801 7891
ρ, g/l 2,015 3,170 4,976 7,645 11,44 16,64
and also data of relative density at different temperature in gaseous phase for this matter:
T, oC 26,4 29,2 33,1 39,2 47,3 88,1
p, mm m.c. 745 750 750 743 745 741
D, air 1,773 1,578 1,321 1,002 0,823 0,713
1) Determine gas A and mineral B
2) Determine compound and structure of this matter in gaseous phase
3) Describe physical properties and give the examples of chemical properties of this compound (reactions with different classes: simple matters, oxides, salts, hydroxides, acids)
4) What was the names of Painter and Physicist?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jul7-12, 06:40 AM   #2
Points 2), 3) and 4) of this task I can solve if I know what the matters A and B. So it is necessary to solve point 1).
I tried to use Mendeleev-Klapeiron equation, through density it becomes following:
M = ρRT/p
But for each occasion I've got... different molar masses! Explain please if it's possible?
I've got the next data:
M, g/mole 94,3 74,9 64,1 57,1 52,5 49,0
It means that during of temperature raising molar mass is decreasing. But it's impossible!
May be, I need to use another equations?
Jul8-12, 03:07 AM   #3
Dear sirs,
I've detected an error in my post. I am sorry.
I mixed up mineral and gas.
1) Determine mineral A and gas B
I also want to say that gas and matter have the same meaning - it is B. I think that problem says that B has different structures in liquid and gaseous phase. All the data relate to B.
I have only one question: how is it possible to determine gas B using pressures of its saturated vapour and relative densities?
New Reply
Tags
pressure, relative density, saturated vapor
Thread Tools
Similar Threads for: Determine the gas if the pressure of its saturated steam is known
Thread Forum Replies
Steam vs Fuly saturated air: Separation General Physics 6
saturated steam pressure Introductory Physics Homework 2
Saturated Steam - Conceptual Question General Physics 0
Saturated Steam Tables - General Question General Physics 1
Thermodynamics: Addition of saturated steam to closed tank Engineering, Comp Sci, & Technology Homework 3
