Charging voltage versus battery voltage
The discussion revolves around the phenomenon of terminal potential difference (p.d.) exceeding electromotive force (EMF) during the charging of batteries. Participants explore the underlying mechanisms, implications, and variations across different battery types.
  • Some participants suggest that the terminal potential difference must exceed the EMF to reverse the chemical reaction that generates the EMF.
  • Others inquire about the specific mechanisms by which the potential difference becomes greater than the EMF during charging.
  • One participant explains that the initial increase in terminal p.d. is due to incoming positive charges, leading to charge accumulation and a gradual increase in potential difference.
  • A mathematical model is presented, indicating that during charging, the relationship between terminal p.d. and EMF changes over time, with terminal p.d. initially being less than EMF.
  • Another participant discusses the impact of charging voltage on current flow and the associated heat generation, noting that different battery types have varying tolerances for charge voltages and currents.
Participants express differing views on the conditions under which terminal p.d. exceeds EMF, with no consensus reached on the specifics of the mechanisms involved or the implications for different battery types.
Some limitations include the dependence on battery type and charging method, as well as the unresolved mathematical steps in the discussion of terminal p.d. and EMF relationships.
moatasim23
Why during charging a battery the terminal Potential Difference becomes greater than the EMF?
I believe it has to in order to reverse the chemical reaction that produces the EMF in the first place.
Well to be more specified.I wanted to ask HOW..
How what? Please be specific when posting questions, or you will confuse people, and more importantly you will confuse me! :biggrin:
Sorry for inconvenience...I wanted to ask:
How the potential difference becomes greater than EMF?
I think the charger is simply set up to apply a greater voltage than the battery produces.
Hi moatasim:)...IN the start you can't roughly say t.p.d will be greater than emf during charging.when u begin charging, the terminal p.d simply increases coz of the incoming positive charges from other source.charge accumulation leads to greater increase in potential difference(as Q is directly related to V). when charge accumulation goes on increasing then incoming positive charge from external source towards negative plate of cell(under charge) will be attracted towards it more strongly and when it reaches negative plate then it is pushed towards positive plate due to increasingly potential difference.as emf is the push of positive charge from negative to positive terminal,then with da increase in time this push becomes more and more ease and less emf though will be due to a p.d cloud.NOW,as you know emf exists even there's no current in circuit and p.d don't exist if there's no current.In start when charging begins,p.d goes on increasing but still be less than emf already present.SO in beginning and till to a particular time t.p.d will be less than emf. MATHEMATICALLY FOR DISCHARGING
t.p.d = E - Ir
V= E - Ir ( E is the electromotive force)
or E=V + Ir ( V is t.p.d)
FOR CHARGING
v = E + Ir (as for charging respective electrodes are alike)
E= V-Ir SO you can clearly see emf decreses by a function of time Q/t.( Ir=Q/t*r) with the passage of time E goes on decreasing and consequently V goes on increasing..I hope you will get it:)
t.p.d = E - Ir
FOR CHARGING
The model for most batteries is of an "ideal" voltage source in series with a resistor. It's that resistor that you need to consider.
* ideal means whatever you need it to, here. :smile:
Batteries produce power via chemical reactions...charging reverses those...the higher the charge voltage the higher the current flow and the faster the reverse chemical reaction.
BUT higher currents [via higher charge voltages] mean more heat and that can ruin batteries...so charge voltages must be limited...
An AGM battery can be charged at it full rated amp hour capacity because it has very low internal resistance, so not much heat is generated during charging, not so for a traditional wet cell lead acid battery which is limited to about 25%. These mean for a battery rated at, say, 100 amp hours, you can safely charge an AGM at 100 amps but a conventional battery at only about 25 amps. In a conventional wet cell lead acid battery about a quarter of the charge power is lost thru heating, only 1 or 2% is lost to heat in an AGM type battery. .
  • · Replies 58 ·
  • · Replies 21 ·
  • · Replies 16 ·
11K
