Clarification regarding Newon's first law.
  • Context: Undergrad
  • Thread starter Thread starter sankalpmittal
    First law Law
The discussion centers around the interpretation and definition of Newton's first law of motion, particularly regarding the role of inertial and non-inertial frames of reference. Participants explore the implications of these frames on the law's applicability and correctness as presented in textbooks versus a teacher's interpretation.
  • Some participants argue that the standard textbook definition of Newton's first law is incomplete without mentioning the necessity of an inertial frame of reference.
  • Others propose that the law serves as a definition for non-accelerating frames and that modifications are necessary when considering accelerating frames.
  • A participant suggests that the teacher's interpretation confuses relative acceleration with frame of reference, asserting that textbooks are not incorrect.
  • Another participant states that Newton's first law should be viewed as a simplified starting principle, emphasizing that all objects are subject to external forces in reality.
  • Some participants contend that the teacher's phrasing is misleading and that the law inherently assumes an inertial frame of reference.
  • One participant mentions that the law does not apply in accelerating frames, thus questioning the validity of applying it in such contexts.
  • Another participant highlights that Newton's first law is fundamentally about defining which frames are inertial, rather than using acceleration to define the law itself.
  • A later reply acknowledges the complexity of the discussion and reiterates the importance of understanding the context of frames of reference.
Participants generally disagree on the interpretation of Newton's first law, with multiple competing views regarding the necessity of specifying inertial frames and the implications of accelerating frames. The discussion remains unresolved with no consensus reached.
Some participants note that the definitions and interpretations of Newton's first law depend on the context of reference frames, which may lead to confusion. The discussion reflects varying levels of understanding regarding the application of the law in different frames.
  • #31
This thread needs to get back on topic or it will be locked. Discussion about philosophy and its function in physics does not belong here.
Zz.
Science news on Phys.org
  • #32
ZapperZ seems to be correct. This thread is really going off topic , rather than being limiting itself to the scope of my question (OP's).
Ok , so my first question has been well answered however second question has not , for I've mistyped it.
Let me repeat it again :2. So teacher's definition is correct then.. However I am not at all convinced by the examples he gave :
He then gave us the following examples :
Suppose a block is kept at rest on a floor. An observer observes this standing beside the block and thus concludes that the block is at rest. So |a| =0
Or |F| =0. So he says that Newton's first law holds.
Another observer in a car is moving with an acceleration towards the block w.r.t ground and observes the acceleration in the block as -a.
So F = -ma
So he says that the Newton's first law is wrong , as there is an external force being applied and object was at rest!
Is he correct ?
Also , suppose a frame is situated in the ship which is non inertial. So Newton's first law will not apply inside the ship (frame) or also outside it ?
Please do not leave any question unanswered now, otherwise I'll have to re-post it.
  • #33
So F = -ma
Is he correct ?
Here's how I would describe those two cases:
(1) A box is at rest with no external forces* acting. It just sits there, so Newton's first law holds.
(2) That same box has no external forces acting yet is seen to accelerate. So Newton's first law does not hold.
Not clear what you mean. If you are viewing things from a non-inertial frame, Newton's first law will not hold.
Edit: I meant, of course, no net external force acting.
  • #34
Is he correct ?
Threats now, eh? :rolleyes:
How can Newton's First Law be 'wrong' about a situation involving acceleration when it specifically refers to a non-accelerating situation?
  • #35
(1) A box is at rest with no external forces acting. It just sits there, so Newton's first law holds.
But is that example correct ? I think that the teacher while giving that example , is confusing frame of references and relative force.
But what I am asking is this :
Earth is practically regarded as inertial frame of reference , right ? Suppose the ship is in acceleration with respect to earth. So ship is a non inertial frame. Now an observer in the ship cannot apply Newton's first law by observing object inside ship , or also cannot apply Newton's first law outside the ship ?
  • #36
The examples, properly explained, are fine. The point is that from a non-inertial frame Newton's first law doesn't hold without modification.
Once again: If you view things from a non-inertial frame, such as your ship, then Newton's first law will not apply. It doesn't matter if you are viewing something that happens inside or outside the ship, as long as you are describing them from the non-inertial frame of the ship then Newton's first law will not apply.
  • #37
It doesn't make any sense to get snippy about your question being unanswered when you mistyped it (rather significantly). You expect us to do you the courtesy of taking the effort to re-answer a question that we already answered (which I will do), so please also do us the courtesy of being polite about your request.
OK we have two definitions of Newtons first law which we would like to apply to this situation:
A) "Every object remains in its original state of rest or uniform motion unless it is acted upon by a net external force."
B) "If observation is being made from an inertial or non accelerating frame of reference , then every object remains in its original state of rest or uniform motion unless it is acted upon by a net external force."
In all reference frames the block is affected by the following two real forces: the weight of the block directed vertically down, and the normal force from the floor directed vertically up. These two forces cancel each other out in all reference frames, for a net force of 0. In the car's reference frame the block is accelerating horizontally at a rate of -a.
Definition A fails because the block is not staying at rest even though it is not acted upon by a net external force.
Definition B succeeds because the observation is being made from an accelerating frame, so the remainder of the definition does not apply.
  • #38
Oh ! Forgot to say thanks !
Thanks for the efforts ...
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 62 ·
27K
