New Reply
What is work?
Share Thread Thread Tools
Aug4-12, 07:48 AM   #1
What is work?
Okay i know that energy is the ability or capacity to do work. But how do you define work, as like the isnt work just the transference of energy in one form to another? Which is kinda circular reasoning. Like the rely on each other for a defintion. Is that right?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Aug4-12, 07:53 AM   #2
Mentor
The appropriate definition of work depends on what theory you are using.
One is the mechanical definition: "work is f.d". This definition is used in basic Newtonian mechanics. In it forces are the primary things and everything else is defined based on forces. Then energy is non-circularly defined as the capacity to do work.
The other is the thermodynamic definition: "work is a transfer of energy other than through heat". This definition is used in Lagrangian and Hamiltonian mechanics as well as all field theories. In these, the Lagrangian is the primary thing and everything else is defined based on the Lagrangian. Then energy is non-circularly defined as the conserved quantity associated with time invariance of the Lagrangian.
Aug4-12, 07:55 AM   #3
Mentor
Quote by hwall95 View Post
You may want to bookmark the Hyperphysics website and use it as a starting point for future querries.
http://hyperphysics.phy-astr.gsu.edu/hbase/wcon.html
Zz.
Aug4-12, 08:03 AM   #4
What is work?
Quote by DaleSpam View Post
hahah yeah thanks i was meaning the thermodynamics definition sorry, okay thanks but when you say "other then heat energy", is that because thermal energy itself is just kinetic energy?
Aug4-12, 08:11 AM   #5
Mentor
No, that is just the definition of work in thermodynamics. Energy can be transfered between systems either through heat, or through anything else. Anything else is called work.
The basic distinction is that heat is a rather disorganized microscopic transfer that you cannot see in detail, as opposed to things like macroscopic fields and forces.
Aug4-12, 08:17 AM   #6
ohhh okay thanks i understand that now, thanks heaps :)
New Reply
Thread Tools
Similar Threads for: What is work?
Thread Forum Replies
Is there a difference between how pem fuel cells work and typical batteries work? Biology, Chemistry & Other Homework 0
Finding velocity and work involving friction Work Energy Introductory Physics Homework 9
The conservation of energy, why does it work? Negative work vs positive work Introductory Physics Homework 54
Partial fractions QUICK question, zero work required, just knowledge of how they work Calculus & Beyond Homework 2
Work to push a sled up a hill: Friction, inclines,force,work Introductory Physics Homework 2
