| New Reply |
swl of a motor |
Share Thread |
| Aug7-12, 12:21 PM | #1 |
swl of a motor
using the following information can anyone tell me if the detailed motor is capable of lifting 90kgs 48"
Nominal speed 40 rpm Nominal torque 5 Nm Nominal voltage 12 V Shaft diameter 9 mm Manufacturer part no. DO 111.3761.2B.00 / 3018 Specification DC gear motor Nominal current 5 A Shaft design With key 3 Type DO11137612B00/3018 http://www.conrad-uk.com/ce/en/produ...01101&ref=list regards red |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Aug7-12, 03:47 PM | #2 |
Mentor
Depends on how fast you want to lift it.
| Aug7-12, 03:50 PM | #3 |
takes about about 10-15 seconds with current motor
| Aug8-12, 01:51 AM | #4 |
swl of a motor
Describe the lift mechanism (i.e., rope on a drum, like a winch), including dimensions.
| Aug8-12, 03:30 AM | #5 |
http://www.bruno.com/vehicle-lift-take-apart-lifts.html this the hoist mechanism |
| Aug13-12, 11:47 AM | #6 |
any ideas people? trying to save a disabled guy £450
| Aug14-12, 06:12 AM | #7 |
Your downward force is 90*9.81 N (call it 900) so if your drum is .037 m radius you need a torque of 33.3 NM so you'd need a 7:1 reduction gearbox.
To raise 90 Kg over 1.2 M you need about 1000 J, 12V*5A is 60w so it would take slightly over 15 seconds for the lift. |
| Aug14-12, 04:25 PM | #8 |
thanks jobrag
thats brilliant |
| Sep20-12, 07:30 AM | #9 |
Jobrag,
I have a question please. If this was an application with a rope wrapped around the drum, would we not consider the diameter of the rope in addtion to the radius of the drum to back calculate the force necessary? |
| New Reply |
Similar discussions for: swl of a motor
| Thread | Forum | Replies | ||
| Does the current drawn by an electric motor increase or decrease as the motor starts | Introductory Physics Homework | 5 | ||
| driving a compact can crusher- stepper motor or gear motor? | Mechanical Engineering | 12 | ||
| winding resistance of large motor vs small motor | Mechanical Engineering | 2 | ||
| Electromagnetic Motor (Simple Motor) & Voltmeters | Advanced Physics Homework | 6 | ||
| Can DC motor works as a stepper motor? | Electrical Engineering | 1 | ||
