New Reply
Specific Heat: Bond or Freedom of Degree Based, Or Size??
Share Thread Thread Tools
Aug12-12, 07:37 AM   #1
Okay so Ive been trying to understand what causes one substance to have a higher specific heat then other but Ive read quite a few conflicting sources in which one says its due to the freedom of degree, while another says the weight of the atom, and then another says its due to the strength of the bonds. For example both ammonia in a solution (NH4+) and water have hydrogen bonding and both have high specific heats, but then they are both larger yet light polyatomic molecules.
So if anyone could shed some light and help me get my head around this, it would be much appreciated. Thanks Heaps :)
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Aug12-12, 09:00 AM   #2
mfb
Mentor
More degrees of freedom per atom => higher specific heat
More atoms per mass (lighter atoms) => higher specific heat (expressed in J/(K*kg))
The strength of the bonds can influence the available degrees of freedom. For example, you cannot excite vibrations in N2 molecules at room temperature (in significant amounts), the required energy is too high. With other molecules, it can be possible to excite them.
New Reply
Thread Tools
Similar Threads for: Specific Heat: Bond or Freedom of Degree Based, Or Size??
Thread Forum Replies
Specific Heat Background Explanation in relation to Degree of Freedom + Energy storag Advanced Physics Homework 0
Unknown specific heat of a mixture of several substances of known specific heat Biology, Chemistry & Other Homework 6
Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity Advanced Physics Homework 4
Specific Heat Capacity and Specific Latent Heat Introductory Physics Homework 2
Masters degree and PhD restrictions for a specific college degree. Academic Guidance 3
