| New Reply |
Can a magnet's magnetic field perform work on another magnet? |
Share Thread | Thread Tools |
| Aug17-12, 04:29 PM | #18 |
Can a magnet's magnetic field perform work on another magnet?As Lubos rightly imo points out in that link I gave, electrons cannot be successfully modeled as the limit of a classical loop current. Electrical interactions of the E.j type simply do not and cannot apply in that wholly QM regime. And it carries over to a permanent magnet as a QM glued ensemble of such. You can dismiss this yet again as 'hand-waiving', but I notice you still haven't supplied any kind of coherent rebuttal to either #5 or #10. Just hope I don't get stuck in a useless circular dialogue with you here. Please, be prepared to shift position, however painful it seems at the time. Must go.
| Aug17-12, 04:33 PM | #19 |
Mentor
| Aug17-12, 04:38 PM | #20 |
Mentor
| Aug17-12, 04:43 PM | #21 |
Respectfully, Steve |
| Aug17-12, 04:52 PM | #22 |
Mentor
| Aug17-12, 04:54 PM | #23 |
Mentor
| Aug17-12, 05:40 PM | #24 |
Respectfully yours, Steve |
| Aug17-12, 07:37 PM | #25 |
Recognitions:
That said, I would argue two things that are in disagreement with that article: (1) The net force on a magnetic dipole placed in a magnetic field [itex] \mathbf{F}=\mathbf{ \mu } \cdot \mathbf{ B }[/itex] is not truly a magnetic force,. It is the net result of the magnetic force on the current elements in the loop and whatever (nonmagnetic!) agent/force is responsible for maintaining the current in the loop (there are of course other forces at play which make the loop go where the current elements go, by keeping the current confined to the loop, but these are irrelevant to this discussion, and incapable of doing work on the loop/dipole as they are internal forces). (2) Since the magnetic force on each current element is always perpendicular to the motion of the current element, the work is not done by the magnetic field, but rather by whatever agent maintains the current in the loop/dipole. |
| Aug17-12, 07:51 PM | #26 |
Recognitions:
As you point out, this model is not entirely accurate ( for one there must somehow be some mysterious energy source which keeps the magnetic dipole moment constant when subjected to external field, not to mention that elementary particles like electrons have a dipole moment associated with them that only comes in quantized values), but it does correctly predict the net force and torque on permanent dipoles without introducing an additional axiom to theory (one treating magnetic dipoles as fundamental and different from the other two types of fundamental sources, point charges and currents). |
| Aug17-12, 07:59 PM | #27 |
Recognitions:
| Aug17-12, 08:35 PM | #28 |
I looked up Poynting's theorem; it seems to have some qualifications.
http://www.phy.duke.edu/~rgb/Class/E...cs/node33.html "It seems, then, that Poynting's theorem is likely to be applicable in a microscopic description of particles moving in a vacuum, where their individual energies can be tracked and tallied: but not necessarily so useful in macroscopic media with dynamical dispersion that we do not yet understand." Respectfully, Steve |
| Aug17-12, 09:53 PM | #29 |
Mentor
| Aug18-12, 03:29 AM | #30 |
My position here is the same as it was in the earlier thread and I would say(with a slight reservation) that magnetic forces can do work.A good example of this was given by Dotini in post 12.
I would justify my position by describing that the force between the magnet and paper clip is best described as being a "magnetic force".It all boils down to accepted definitions and having done some searches,my impression is that there seems to be a majority who refer to such forces (and the force on a current carrying wire in a B field) as being magnetic. My reservation stems from the fact that there are four fundamental forces named,in brief,as: Weak Strong Electromagnetic Gravitational Forces,of course,are given other,more specialised names depending on the situation being considered.There's quite a long list of forces which includes,turning forces shear forces drag etc. These other named forces may well be combinations of one or more of the four main forces but that is usually irrelevant.Suppose,for example,that an applied physicist or engineer was on a problem calculating work done against friction and then somebody came along and claimed "in actual fact the frictional force is electromagnetic in nature and blah blah blah".The physicist/engineer probably won't give a hoot and continue to refer to it as a frictional force. Perhaps there would be agreement if the forces discussed in these threads were best described as electromagnetic forces. |
| Aug18-12, 05:17 AM | #31 |
Mentor
| Aug18-12, 07:12 AM | #32 |
My post above refers to definitions,accepted nomenclatures.What word(s) would you use to name the force on the paperclip or the current carrying wire?The "magnetic" force seems to be a preferred description according to searches I have made so far.See,for example,the MIT lectures on the subject.
If we were not to call it the magnetic force then I have suggested that the electromagnetic force may be a better description,but is this being too fussy?.I imagine that most text books(at least up to A level standard)would still continue to refer to the "magnetic" force so as to distinguish it from the electric force between stationary charges. |
| Aug18-12, 07:19 AM | #33 |
I would have to look at how the E.j approach applies to paper clip/magnet type scenarios but I think I already agreed that it is relevant to current carrying wires.In the previous thread I suggested that E needs defining since there is the E.j due to the power supply which is the source of the energy and the E.j due to the back(counter emf) which illustrates the power output.
| Aug18-12, 07:27 AM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: Can a magnet's magnetic field perform work on another magnet?
| Thread | Forum | Replies | ||
| Calculating the Magnetic Field due to a Bar Magnet | Introductory Physics Homework | 4 | ||
| Magnetic Field of a Bar Magnet | Classical Physics | 1 | ||
| Magnetic field of a bar magnet | Advanced Physics Homework | 3 | ||
| How do I contain a magnet's magnetic field? | General Physics | 6 | ||
| what make the magnet to be magnet with magnetic field? | General Physics | 23 | ||
