Electrostatic Induction and Spray Painting
The discussion focuses on understanding the charge on paint droplets in electrostatic spray painting. It describes the process where a grounded nozzle feeds paint, while an insulated electrode creates an electrostatic field that charges the paint. The charge density in the paint is influenced by the strength of the electrostatic field and the paint's properties. The charge on individual droplets is determined by their volume and the charge density from the paint source. The original poster seeks equations and guidance to further explore this topic, indicating a need for clarity on the relationship between electrostatic principles and spray painting.
window
Hi,
What is the charge on a droplet of paint?
Im trying to understand what's going on in electrostatic spray painting - specifically at the spray nozzle (this could also be crop spraying too)
My understanding so far is that a paint supply is fed into a grounded nozzle. An electrode (le'ts say it's ring shaped) sits around the nozzle. The electrode is insulated from the paint so that no current can flow between the two.
The electrostaic field impinges on the paint. In the paint like charges are repelled and unlike charges attract towards the electrode. The paint in the end of the nozzle is charged.
When droplets of paint are formed in spray they are also charged. I want to develop and expression for the charge on the droplet of paint.
I imagine I'm going to break the problem down as follows:
1. the electrostatic field strength in the paint is a function of the electrode voltage, distance, and a property of the air seperating the two.
2. the density of the charge induced in the paint is a function of the electrostatic field strength, and a property of the paint to do with the mobility of electrons in the paint.
3. the charge on a droplet will depend on its volume, and the charge density of the paint it came from.
Does this seem about right or have I made some dumb mistakes in this?
I have read some info on Coulombs law, but I don't seem to be able to relate it here...I think that's the burden of my lumbering brain though.
Any pointers to equations / laws for 1,2, & 3 above would be very helpful - I can then try to get my head around it - I'm just finding it difficult to get started.
Thanks very much for any help with this, I'm really stuck.
Did you get any solution to this?? I am trying to find the same thing but can´t... can you send me an email if you do?
bernyag@hotmail.com
Thanks!
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
