| New Reply |
Metric tensor Determinant |
Share Thread |
| Aug17-12, 09:19 AM | #1 |
Hello,
So, given two points, [itex]x[/itex] and [itex]x'[/itex], in a Lorentzian manifold (although I think it's the same for a Riemannian one). If in [itex]x[/itex] the determinant of the metric is [itex]g[/itex] and in the point [itex]x'[/itex] is [itex]g'[/itex]. How are [itex]g[/itex] and [itex]g'[/itex] related?By any means can [itex]g=g'[/itex]? In what conditions? I'm sorry if this is a dumb question but when prooving an equation I found out that it holds only if and only if [itex]g=g'[/itex] and I don't think that this is always true. Thank you. |
| Aug17-12, 01:29 PM | #2 |
Mentor
These are two different points, right? If so, there is, in general, no relation between [itex]g[/itex] and [itex]g'[/itex].
If it is actually two different coordinate representations of the same point, then [itex]g' = J^2 g[/itex], where [itex]J[/itex] is the Jacobian of the coordinate transformation. |
| Aug18-12, 04:42 PM | #3 |
Thank you for the prompt response.
The notation might have not been the best, sorry; it were two distinct points in a manifold. What if the point [itex]x'[/itex] were in a sufficiently small neighborhood of [itex]x[/itex] and vice versa (the neighborhoods may not be the same). Aren't tensors defined in a small neighborhood of a point: since they represent a multilinear map? Thank you, and sorry if i'm really confused about the concepts. |
| Aug18-12, 05:18 PM | #4 |
Given a manifold, you can put any metric on it that you like. Just choose any smooth function that has the same signature everywhere.
It would be unusual if the signature of the metric varied from point to point. If this happens in actual applications, it's usually a sign that you chose a bad coordinate system, which can be related via a singular transformation to some other, better system of coordinates. (Differential geometry is agnostic about coordinates, but only up to a smooth, one-to-one mapping, not up to any mapping at all.) I think the metric does have to be free of intrinsic singularities (as opposed to mere coordinate singularities). When a singularity turns up in general relativity, for example, we define the singularity not to be a point in the manifold at all. So for this reason, I think the answer to your #3 is that yes, g and g' are related if x and x' are close. For x and x' sufficiently close, g and g' can be made as close as desired. |
| Aug26-12, 01:41 PM | #5 |
Recognitions:
| Aug26-12, 05:31 PM | #6 |
| Aug30-12, 10:58 AM | #7 |
| Aug30-12, 05:27 PM | #8 |
![]() Well, in this particular case I interpreted that "we" in "we define..." to be referring to physicists, so it would be more of a well-respected "mathematical physics" method.
| New Reply |
Similar discussions for: Metric tensor Determinant
| Thread | Forum | Replies | ||
| What different between covariant metric tensor and contravariant metric tensor | Differential Geometry | 3 | ||
| Derivative of contravariant metric tensor with respect to covariant metric tensor | Calculus & Beyond Homework | 0 | ||
| energy-momentum tensor: metric tensor or kronecker tensor appearing? | General Physics | 2 | ||
| Having trouble writing down a metric in terms of metric tensor in matrix form? | Special & General Relativity | 4 | ||
| relationships among metric structure, metric tensor, special and general relativity | Special & General Relativity | 18 | ||
