 Quote by spuding102
Yes in a brief sense.
Edit: I understand fields and such but not on a advanced level but good enough to understand when you are talking about a field
Well, I'm probably going to butcher this explanation, but I'll have a go at it.
In developing Quantum Field Theory, it was discovered that we can mathematically model the various forces as interacting with particles by saying that "virtual particles" are exchanged between two particles. Imagine two ice skaters skating parallel to each other. One tosses a ball to the other one. The force of the throw causes the first one to move away, while the catch does the same thing to the other skater. Thus both skaters were "repulsed" from each other by throwing a ball.
QFT describes interactions in a way similar to this, only it's way more complicated since we obviously cannot explain an attraction using the same analogy. Virtual particles can cause attractions as well as repulsion. (Imagine the thrown ball where the math works in reverse. The thrower and catcher move towards each other)
From wiki:
A virtual particle is one that does not precisely obey the m2c4 = E2 − p2c2[3] relationship for a short time. In other words, its kinetic energy may not have the usual relationship to velocity–indeed, it can be negative. The probability amplitude for it to exist tends to be canceled out by destructive interference over longer distances and times. A virtual particle can be considered a manifestation of quantum tunnelling. The range of forces carried by virtual particles is limited by the uncertainty principle, which regards energy and time as conjugate variables; thus, virtual particles of larger mass have more limited range.
There is not a definite line differentiating virtual particles from real particles — the equations of physics just describe particles (which includes both equally). The amplitude that a virtual particle exists interferes with the amplitude for its non-existence, whereas for a real particle the cases of existence and non-existence cease to be coherent with each other and do not interfere any more. In the quantum field theory view, "real particles" are viewed as being detectable excitations of underlying quantum fields. As such, virtual particles are also excitations of the underlying fields, but are detectable only as forces but not particles. They are "temporary" in the sense that they appear in calculations, but are not detected as single particles.
The short version is that the math describes both real and virtual particles equally well. It just boils down to which ones we can directly detect. For example, if a photon is detected by your eye or a camera, that is a "real" photon, not a virtual one. Virtual ones carry momentum between particles that interact via electromagnetism.
I'm sorry if that's a terrible explanation, as my understanding of virtual particles is not very good lol.
Edit: Before you ask I want to tell you that the interpretation of whether virtual particles "actually exist" or whether it is simply a "mathematical concept" is a VERY heated one that has happened several times since I've been here on PF.
