New Reply
Discrete Fourier Transform with different period
Share Thread Thread Tools
Sep13-12, 05:38 PM   #1
Hi all, I have a seemingly simple problem which is I'd like to efficiently evaluate the following sums:
[tex]
Y_k = \sum_{j=0}^{n-1} c_j e^{\frac{i j k \alpha}{n}}
[/tex]
for [itex]k=0...n-1[/itex]. Now if [itex]\alpha = 2\pi[/itex], then this reduces to a standard DFT and I can use a standard FFT library to compute the sums. But if [itex]\alpha \ne 2\pi[/itex] then I don't see how I can put this into standard DFT form to use a regular FFT library on this.
I guess this problem amounts to computing a DFT with harmonics that do not necessarily have periods of [itex]2 \pi[/itex].
Any help is appreciated!
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Sep13-12, 06:56 PM   #2
Math 2012
Recognitions:
This situation happens all the time when you analyse measured data, because obviously you don't know exactly what frequencies are in the data till AFTER you have measured it and processsed it.
If you do a DFT on the raw data, the result will be hard to understand, because the discontinuity between the two ends of the sample will produce a lot of high frequency Fourier components that don't mean anything physically.
One standard technique is to multiply the data by a "windowing function" which is close to 0 at the ends of the range, and close to 1 in the middle. That gets rid of the meaningless high frequency fourier components by making the ends of the sample "match up" (both become close to 0), but at the cost of blurring the frequency components you are intrested in.
There are several different windowing functions that have been invented, with different tradeoffs between the amount of filtering and the amount of blurring, but if you are new to this I would recommend the Hanning window
http://en.wikipedia.org/wiki/Hann_function Note, there is also a Hamming window - be careful with the spelling!
This might be useful: http://www.tmworld.com/electronics-n...Results-Part-I (and also part 2)
"Real world" signal processing programs like Matlab have these windowing options built in, so you don't have to work out the math yourself.
New Reply
Thread Tools
Similar Threads for: Discrete Fourier Transform with different period
Thread Forum Replies
The discrete fourier transform Advanced Physics Homework 1
Mathematica: Discrete Fourier Transform Math & Science Software 9
conditions for non-zero discrete Fourier transform? Calculus 0
Discrete Fourier Transform Engineering, Comp Sci, & Technology Homework 1
Discrete FOurier Transform Calculus 0
