New Reply
Relationship between changing a wire's diameter and change in temp
Share Thread
Sep20-12, 03:20 AM   #1
1. The problem statement, all variables and given/known data
Hello! I have a problem where I need to develop and justify a hypothesis surrounding the relationship between the thickness (or diameter) of a nichrome wire and the temperature of water that it's submersed in over a time of 5 minutes. (proportionality statement and equations)
2. Relevant equations
So far, I know that resistance is inversely proportional to cross-sectional area, and therefore:
R ∝ 1/A
R ∝ 1/∏r^2
R ∝ 1/∏(d/2)^2
and because 2 and ∏ are constant
R ∝ 1/d^2 (resistance is inversely proportional to diameter squared) (I think!)
Now, I've also researched Joule's law, which eventuates into:
Heat produced = Pt = VIt = V^2/Rt = I^2Rt
3. The attempt at a solution
Now, I'm trying to get a relationship between diameter and ΔT, and I thought, so I have R ∝ 1/d^2, and P = V^2/R where V is a constant so P ∝ 1/R
and since P is the change in heat:
ΔT ∝ 1/R
OR
since thickness makes resistance go down
and less resistance makes ΔT (somehow)
then is R ∝ ΔT
and substituting so therefore:
ΔT ∝ 1/d
and I don't have much idea how to reason out what the graph will look like/why...
I think I've tied myself in knots... any help would be much appreciated! Thank you!:)
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Sep20-12, 06:03 AM   #2
I think you have to assume the wire is connected to a constant voltage source and I'd also ignore any change in resistance of the wire with temperature.
Therefore your approach is correct..
R ∝ 1/∏(d/2)2
R ∝ 1/d2
Then use..
Power = V2/R
Power = V2 * d2.........................................(1)
If the water is in an insulated container then the energy it contains (E) is given by
E = Specific heat capacity * mass * Δ Temperature
Rearrange to give..
Δ Temperature = E / Specific heat capacity * mass
Then..
E = Power * Time
so
Δ Temperature = Power * Time / Specific heat capacity * mass ...............(2)
Put (1) into (2)...
Δ Temperature = V2 * d2 * Time / Specific heat capacity * mass
Voltage, Time, Specific heat capacity and mass are all constant so
Δ Temperature ∝ d2
eg The change in temperature over 5min (not the actual temperature) is proportional to d2
Temperature = Initial Temperature + Δ Temperature
So actual temperature is proportional (but not directly proportional) to d2.
http://en.wikipedia.org/wiki/Proport...y_(mathematics)
New Reply
Tags
cross sectional area, joule heating, nichrome wire, ohm's law, thermo dynamics
Similar Threads for: Relationship between changing a wire's diameter and change in temp
Thread Forum Replies
Fluid mechanics...Volume change with temp change Engineering, Comp Sci, & Technology Homework 1
Total charge through point on wire due to changing current on other wire Advanced Physics Homework 1
Fabricate uniform wire out of 2.1g of copper w/ 0.3 ohm resist. - wire diameter? Introductory Physics Homework 2
Time-Temp relationship with water/ice phase-change Classical Physics 1
[SOLVED] Density Change Caused by Temp. Change Introductory Physics Homework 3
