| New Reply |
Shielding a magnetic field |
Share Thread |
| Sep25-12, 04:25 AM | #1 |
Hi everyone,
I have two questions related to magnetic fields. Firstly, if I have two bar magnets with opposite poles facing each other, ie NS - NS, how do I measure the magnetic field strength at any point between the two magnets? Secondly, how would I shield the magnetic fields of the bar magnets in a box so they are not detectable outside? Any help would be appreciated, thanks. |
| Sep25-12, 05:02 AM | #2 |
Better way to prevent all the magnetic field lines from coming outside of the box is, use a box made up of a super conductor to separate bar magnets. The super conductor plate is able to divert all the field lines.
| Sep25-12, 05:53 AM | #3 |
Use a "Hall Probe" (http://en.wikipedia.org/wiki/Hall_effect_sensor) to measure the magnetic field from the Bar Magnet.
To shield the magnetic field , you could use an iron box to enclose the bar magnets . (or a thin layer of iron foil would also suffice) |
| Sep25-12, 09:13 AM | #4 |
hi.hms.tech I dont think a iron box can separate magnetic field lines. I have doubt about it. Can you explain?
| Sep25-12, 07:13 PM | #5 |
Thank you for your replies.
Also for the iron box shielding, how do I calculate the change in field strength across the shielding? Thanks again. |
| Sep25-12, 07:31 PM | #6 |
Mentor
Check out the FAQs section of Magnetic Shield Corporation's website:
https://www.magnetic-shield.com/sitemap.html They mostly sell netic and conetic magnetic shield material and shapes, but the concepts would apply to iron shielding as well. |
| Sep25-12, 08:04 PM | #7 |
Thanks for that - that will be useful.
However, if I have a shield at a distance from a magnet, how do I calculate the field at that distance? In a related question, if I have two magnets, how do I calculate the field strength at any point between them - is it merely by superposition or are there other parameters to take into account? |
| Sep26-12, 07:16 AM | #8 |
I would look into an advanced electrodynamics textbook, there are closed form solutions for what you need, although they will be very very complicated and require a far field approximation.
| New Reply |
Similar discussions for: Shielding a magnetic field
| Thread | Forum | Replies | ||
| magnetism: conditions for magnetic attraction and magnetic shielding | Classical Physics | 6 | ||
| Shielding from electric/magnetic field using a metal box | Classical Physics | 6 | ||
| Magnetic Field Shielding | Advanced Physics Homework | 3 | ||
| Magnetic shielding, or field line redirection - why does it work ? | General Physics | 3 | ||
| What magnetic shielding should I use? | Electrical Engineering | 18 | ||
