How do I calculate the force of an object attached to a spring?
  • Thread starter Thread starter seallen
    Force Spring
The discussion focuses on calculating the force exerted by an object attached to a spring using experimental data. The key equation is F=ma, where 'm' represents the mass of the object in kilograms. The participants clarify that the force to be calculated is the weight acting under gravity when the spring is loaded, necessitating the use of the spring modulus for accurate calculations. The confusion arises from the interpretation of acceleration in the context of the spring's oscillation and the importance of the spring's mass in the calculations.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of spring mechanics and spring modulus
  • Familiarity with oscillatory motion and its characteristics
  • Basic experimental data analysis skills
  • Research the concept of spring modulus and its role in force calculations
  • Learn about the principles of oscillatory motion and energy conservation in springs
  • Study how to calculate gravitational force using mass and acceleration due to gravity (g)
  • Explore methods for analyzing experimental data in physics, including error analysis
Students in physics, educators teaching mechanics, and anyone involved in experimental physics who seeks to understand the relationship between mass, force, and spring dynamics.
seallen
I gathered the following data in an experiment:
Trial Mass (kg) Stretched Spring (m) Force (N) Highest Point (m) Lowest Point (m)
1 .05 .05 ? 0 .09
2 .1 .095 ? .015 .185
3 .25 .245 ? .065 .45
In the experiment i attached different weights to a spring and measured the spring first as it was stretched and I then released the spring to see the highest and lowest points. I now am supposed to calculate the force in Newtons for each trial.
F=ma I know is the equation for force but how is it applicable to this data? I understand m would be equal to the mass of the object in kg, but how would I find a for the equation?
I originally thought that I would use the stretched spring as a, but now I am not so sure, would I use the change in the highest and lowest point instead? however, acceleration really doesn't apply here so I am confused.
Please clarify that. When you released the spring, there were no weights left on it? And you measured the highest point it reached when it bounced back (and it continued to oscillate?).
If so, that's not good. The mass of the spring has become important.
What force are you trying to calculate? The force when the spring was loaded was the weight acting under gravity. Are you trying to estimate g? You'll need the spring modulus in that case.
  • · Replies 56 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 20 ·
