| New Reply |
3 wheel Bicycle design: Front Axle |
Share Thread | Thread Tools |
| Oct29-12, 06:48 PM | #1 |
I'm trying to understand the angles and force involved with my current project of building a 3 wheel front loading cargo bicycle. The current design stipulations maintain that the rear wheel always remain inline with the cargo(There are a vast majority of designs that do not adhere to this). I'm trying to develop the front axle system and have seen one design that links the headset to the left wheel and then runs a straight rod to the right wheel. I would like to split the axle underneath of the cargo box, in the shape of a T.
If I have a rod to the center of the cargo box directly between the two wheels, when the headset turns it will move the rod towards one wheel, and away from the other. This creates an arc that I can adjust based upon the turning radius of the handlebars. My thoughts on this though are that if the side axles to the wheels are mounted directly centrally in the hubs, then this force of pushing/pulling is going to achieve nothing because the force is directly perpendicular to wheels? How do I translate this arc into a pushing of one wheel, and an equal force of pulling on the other wheel to ensure they remain in unison, and turn in the proper direction? |
| Oct30-12, 12:13 PM | #2 |
So after some thought, I am considered not making a T design, but using a Y design with with either a central pivot point creating equal distance arms from the headset and wheels to a central focal point, or possibly just using two equal distance arms from the headset to the wheels without a central connection point. The underlying problem that I can't quite understand is that the points are all fixed, and the rod lengths are fixed as well, which means everything is bound up and can't articulate.
| Oct30-12, 04:56 PM | #3 |
I'm having a hard time visualizing your design. Can you post a drawing? Even a rough sketch would be helpful.
| Oct30-12, 05:54 PM | #4 |
This might be useful for me. I'm working on my 2 wheeled Unicycle.
| Nov3-12, 11:23 AM | #5 |
Is this what you are talking about? Or something similar?
http://www.buildyourowngokart.com/on...ngAssembly.php Or http://en.wikipedia.org/wiki/Ackerma...ering_geometry |
| New Reply |
| Thread Tools | |
Similar Threads for: 3 wheel Bicycle design: Front Axle
| Thread | Forum | Replies | ||
| Wheel pivoted about a frictionless axle - moment of inertia, force of axle | Introductory Physics Homework | 0 | ||
| Friction and the difference between rear-wheel, front-wheel and four-wheel | Engineering, Comp Sci, & Technology Homework | 3 | ||
| How much ahead the front axle does the wheel jet the water that it pick | Introductory Physics Homework | 0 | ||
| How much ahead the front axle does the wheel jet the water that it pick | Introductory Physics Homework | 4 | ||
| at what angle can you put the front wheel of a bicycle and still be able to steer it? | Classical Physics | 1 | ||
