About the properties of infinity
  • Context: High School
  • Thread starter Thread starter shivakumar06
    Infinity Properties
The discussion revolves around the properties of infinity, particularly in relation to the representation of numbers like 9999999... and the implications of categorizing infinity as odd or even. Participants explore various concepts of infinity, including countable and continuous infinities, and the challenges associated with set theory and the continuum hypothesis.
  • Some participants argue that if 9999999... is considered infinitely repeated, it could be viewed as the largest number without operations, suggesting infinity might be odd.
  • Others contend that the notion of infinity needs expansion, stating that the concept of even or odd does not apply to infinity.
  • A participant questions why 9999999... is not considered a number, seeking clarification on its definition.
  • Another participant emphasizes that infinity is a process related to limits rather than a fixed value, referencing complex analysis and the subtleties involved.
  • Discussion includes the idea that set theory, particularly regarding the continuum hypothesis, is inconclusive, with some participants noting that it is consistent but unprovable within current axioms.
  • Some participants express concern over introducing complex issues like Cantor's set theory when discussing simpler concepts, while others argue that such complexity can be necessary for understanding.
  • There is mention of ongoing attempts to prove or disprove the continuum hypothesis, with a distinction made between serious mathematicians and non-professional attempts.
Participants do not reach a consensus on the nature of infinity or the implications of the continuum hypothesis. Multiple competing views remain, particularly regarding the classification of infinity and the validity of certain mathematical concepts.
Limitations include the ambiguity in defining what constitutes a number like 9999999..., the varying interpretations of infinity, and the unresolved status of certain mathematical theories within set theory.
shivakumar06
If we consider a number 9999999………. infinite times then no other number that can be represented bigger than that without plus or multiply operation. So we can be sure infinity is an odd number am I right
your notion of infinity needs to be expanded:
http://en.wikipedia.org/wiki/Infinity
You're thinking of a countable infinity and the notion of even or odd makes no sense. Why not add zeros to 1 to produce a million, billion, ... googleplex... all even but no different than 999999...
Except that 99999999... is not actually a number.
may i just know why 9999... not a number? can you please throw some light on it?
Well, the first thing you will need to do is to actually define what you mean with 9999...
Hi. You are trying to assign a value to a notion of "infinity". There is no value for "infinity". "Infinity" is a process, a limiting process, a keyword for:
What happens if a quantity grows ever larger and larger?
There is a point at infinity in complex analysis, but to analyse it, You need to use limits, so "Point at infinity" is a mis-nomen, I'd say, just a shorthand notation for something more subtle.
This is all according to Weirstrass and analysis.
And yes, there are "countable" infinities and "continuous" infinities. If You decide to explore Cantor's set theory about types of infinities, be warned: set theory is inconclusive in Godel sense. Continuity theorem is both provable and not provable. This drove Cantor mad and put him into asylum.
I deliberately use layman jargon here for obvious reasons.
Good luck!
Yes, and so is the theory of natural numbers. I don't see anybody warning people for using natural numbers.
First of all, it's the continuum hypothesis. Second of all, it is not "both provable and not provable", that would be a contradiction. Rather, the continuum hypothesis is consistent with set theory and the negation is also consistent. So it is not provable, using the current axioms.
Cantor himself never realized this about the continuum hypothesis. That the continuum hypothesis was consistent was known much later by Godel. That it was unprovable, even later, by Cohen. What drove Cantor mad was rather that his theory was not accepted by his peers.
Yes, awkward situation :smile:
The point is: explaining some issue by introducing another, even more complicated issue, is not a good way to explain anything. Therefore the warning about diving into the Cantor's set theory :smile: For instance, I can still today find manuscripts on-line trying to prove or disprove Cantor's continuum hypothesis, even on arxiv.
Cantor could not prove nor disprove his Continuum hypothesis. One day he wrote a letter to his publisher and editor that he finally managed to prove it. The very next day he urgently sent another letter apologizing for such a childish excitement, for the very last night he actually proved it wrong. Then the next day... And so on. For Cantor himself, it was a hypothesis alright.
Besides, the original question was not quite technical, so my answer was not quite technical either.
Finally, only Cantor knew what was the issue within his mental reasoning that drove him mad -- even maybe Cantor himself could not articulate it. His late father; his childhood; religion; math as religion; loneliness; how can math be inconclusive; if conclusive -- then what's wrong with him; how could God allow this; not eating well... The point here being: we will probably never know.
Regards.
I don't see why not. In physics, we explain classical mechanics by introducing relativity and quantum mechanics, which certainly are much more complicated.
Those manuscripts are not of professional mathematicians then. For mathematicians, the issue is solved. Unless of course you work in other axiom systems, but that is a different issue entirely. Just because some crackpots out there try to disprove an entire theory, doesn't mean that the issue isn't resolved for serious mathematicians.
Also, being published on the ArXiV doesn't mean that the paper is of a good quality, let alone that it is true.
True that. I was simply preventing possible future confused questions. We both agree. Regards :)
Edit: by the way, do You happen to know the answer to my post "Reference or explanation on zeta Mellin transform in critical strip"? It would be really helpful to me if someone could give me a book reference for it. It was posted today in Number Theory section. Thanks in advance.
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 30 ·
