| New Reply |
Modulo and prime numbers |
Share Thread | Thread Tools |
| Nov4-12, 02:49 PM | #1 |
[tex]f(x)[/tex] will give us the smallest integer [tex]m[/tex] such that [tex]y^m \equiv 1 \bmod{x}[/tex] given that x and y are coprime
how would one go about showing that this function is multiplicative? I'm trying to do some Number Theory self study, and the problems I'm encountering are quite difficult to figure out from text alone. I'm guessing that the Chinese remainder theorem is applicable here. Also if we let p be prime then I know that f(p) will give the result of (p-1). This is basically proved with Euler's theorem. Is this true or is Euler's theorem not so easily applicable here? I guess the fact that here m is the smallest integer, where's in Euler's it's not the smallest, but it's easy to prove that this doesn't matter using groups. |
| Nov9-12, 11:19 PM | #2 |
Recognitions:
How does y come in? Is it another given? If so, isn't it f(x, y)?
| Nov10-12, 08:10 AM | #3 |
| Nov10-12, 03:46 PM | #4 |
Recognitions:
| Nov10-12, 07:29 PM | #5 |
i don't think it's Euler's totient function.
for example, consider x = 37; y = 3. both prime, but the smallest m value is not 36, its 18. |
| Nov10-12, 10:18 PM | #6 |
Recognitions:
| Nov11-12, 05:30 AM | #7 |
The totient function gives you an upper bound for f(x), but it is not necessarily the same as f(x). A counterexample occurs with x=12.
The coprimes to x are 1, 5, 7 and 11. An exponent of 1 won't work, but 2 will: 1^2 == 1 (mod 12) 5^2 = 25 == 1 (mod 12) 7^2 = 49 == 1 (mod 12) 11^2 = 121 == 1 (mod 12) so f(12)=2, while phi(12)=4. (I I understood the problem correctly, f(x) would be the order of the multiplicative group modulo x. As such, f(x) divides phi(x), but it's not necessarily equal.) (By the way, f(3)=2 and f(4)=2, but f(12)=2 and not 4, so f(x) cannot be multiplicative.) |
| New Reply |
| Thread Tools | |
Similar Threads for: Modulo and prime numbers
| Thread | Forum | Replies | ||
| Calculation of Large Exponents Modulo a Prime | Calculus & Beyond Homework | 2 | ||
| Order of 3 modulo a Mersenne prime | Linear & Abstract Algebra | 4 | ||
| modulo a prime | Calculus & Beyond Homework | 1 | ||
| binomial coefficient modulo a prime | Linear & Abstract Algebra | 1 | ||
