New Reply
Directional Derivative and Gradient Problem
Share Thread Thread Tools
Nov12-12, 08:28 AM   #1
Suppose that an object is moving in a space V, so that its position at time t is
given by r=(x,y,z)= (3sin πt, t^2, 1+t)
How to find the direction of the vector along which the cat is moving
at t = 1?
I have no idea where to find out the direction of the vector along which the object is moving.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Nov12-12, 01:11 PM   #2
Recognitions:
Gold Membership Gold Member
It seems like you wouldn't even need to use the gradient or a directional derivative to do this. If you took AB/BC Calc you might remember how to differentiate a parametric function of one variable, you can do that and then you'll get that velocity vector, from there the direction should fall straight out (directly if all you need is a direction vector, and with a little bit of trigonometry if you want angles).
If you need help, remember that ##\frac{d}{dt}r(t)= (x(t),y(t),(z(t)) \Rightarrow (\frac{d}{dt}x(t),\frac{d}{dt}y(t),\frac{d}{dt}z(t))##
Nov12-12, 08:07 PM   #3
By differentiating them with respect to t, I should get the velocity vector (x,y,z) = (3 π cos π t, 2t , 1). Then substitute t = 1, (x,y,z) = (-3π, 2, 1).
This is my velocity vector. So how I get the director of the vector when t=1?
Nov12-12, 08:53 PM   #4
Recognitions:
As I said, it depends on what you mean by direction. When my professor asks for a direction, he means a direction vector; a.k.a. a unit vector in the direction of the velocity vector. Remember this is accomplished by dividing all three components by the magnitude (length) of the vector, which you find through the pythagorean theorem.
If you want actual spherical angle directions, you'll have to work through the trig.
Nov12-12, 09:15 PM   #5
Sorry, my mistake.
So if I am looking for direction vector, I just get this (-3π, 2, 1)/(magnitude of this vector (-3π, 2, 1)) where (-3π, 2, 1)=the velocity vector?
Nov12-12, 09:32 PM   #6
Recognitions:
Yes, and the magnitude will be ##\sqrt{(-3\pi)^2+4+1}##.
Nov14-12, 12:48 AM   #7
Understood, thank you very much
Nov14-12, 06:39 AM   #8
thank you... very helpful!
New Reply
Thread Tools
Similar Threads for: Directional Derivative and Gradient Problem
Thread Forum Replies
Gradient vs. Directional Derivative Calculus 12
Directional derivative and the gradient - confused. Calculus 19
Problem with gradient vector, gradient, and directional derivative, etc. Calculus & Beyond Homework 1
Directional derivative and gradient concepts Calculus & Beyond Homework 1
Gradient exists but directional derivative does not? Calculus & Beyond Homework 4
