How to get critical temperature from experiment?
  • Context: Undergrad
  • Thread starter Thread starter Outrageous
    Experiment Temperature
The discussion revolves around methods for experimentally determining the critical temperature of a substance. Participants explore various approaches, definitions, and considerations related to the critical temperature in the context of phase transitions and vapor-liquid behavior.
  • Some participants suggest plotting P-V graphs to analyze the shape for determining critical temperature, while others seek alternative methods.
  • One participant defines critical temperature as the temperature above which a vapor cannot be liquefied regardless of pressure, proposing a method involving constant volume heating until no liquid remains.
  • Another participant argues that critical temperature is not unique at any given pressure and suggests looking for the critical point where latent heat of transition approaches zero, using a constant pressure calorimeter to identify the transition temperature.
  • A later reply mentions that surface tension at critical temperature approaches zero, proposing that measurements of surface tension could help estimate critical temperature, though noting the difficulty in measuring near the critical point.
  • One participant emphasizes the need for sufficient liquid fraction in experiments to avoid complete evaporation before reaching critical temperature, suggesting calculations based on known vapor-liquid equilibrium (VLE) and pressure-volume-temperature (PVT) behavior.
  • Participants inquire about the definitions of VLE and PVT, with clarifications provided regarding their meanings and relevance to the discussion.
Participants express differing views on the methods for determining critical temperature, with no consensus reached on a single approach. Multiple competing ideas and methods remain under discussion.
Participants note the importance of initial conditions, such as liquid fraction, and the complexities involved in measuring properties near the critical point. There are references to specific behaviors of substances that may influence experimental outcomes.
Outrageous
Besides plotting P-V graphs,then see the graph shape.
Do we have any other way to get the value of critical temperature of a substance?
Thank you.
Science news on Phys.org
Thank you.
What is your understanding of the definition of the critical temperature? This should help you identify a method.
Critical temperature of a substance is the temperature which the vapour of the substance cannot be liquefied no matter how high pressure applied to the vapour.
So I should keep the volume constant and then heat the liquid inside the fixed volume until at a temperature ,there will no more liquid? Then at that pressure will be the critical pressure.
There is nothing really special about critical temperature at any given pressure.* So I don't think there is a direct experiment to look for critical temperature. You can, however, look for critical point which will give you both critical temperature and critical pressure. You do this by following along the transition point until the latent heat of transition goes to zero.
For example, you can use a constant pressure calorimeter, supply heat at steady rate and track temperature change. Look for the place where temperature temporarily levels out - that's your transition temperature. Increase pressure and repeat. The plateau will now have narrower range in energy. Keep increasing pressure until that plateau disappears. That's your critical point.* Edit: Actually, there is an estimate you can make based on surface tension and Eotvos rule. Surface tension at critical temperature does go to zero, so I guess, I shouldn't say that there is nothing special. I suspect, it's very difficult to measure the surface tension near the critical point, but you should be able to at least extrapolate the approximate critical temperature by taking measurements at different temperatures. If nothing else, this will tell you where to look for critical point in finer detail.
That could work, but you have to be sure that you have enough liquid fraction initially within the container so that all the liquid doesn't evaporate before you reach the critical temperature. Completely filling the container initially should do the trick, but you should do some calculations for various liquids of known VLE and PVT (vapor) behavior to make sure that that is the case.
You can also use the definition. Start our with vapor in a container at a fixed temperature, and increase the pressure isothermally until liquid (fog) starts to form. If it does, start again at a higher temperature. Keep increasing the temperature until liquid no longer forms no matter how high the pressure.
Chestermiller said:
but you should do some calculations for various liquids of known VLE and PVT (vapor) behavior to make sure that that is the case..
What are VLE and PVT?
VLE stands for vapor-liquid equilibrium (saturation pressure vs saturation temperature). PVT stands for pressure, volume, temperature behavior; in this case, I meant it to mean the PVT behavior of the vapor.
  • · Replies 28 ·
