| New Reply |
Sugestions to solve this equation |
Share Thread | Thread Tools |
| Nov13-12, 03:42 PM | #1 |
Any sugestions on how to find the solutions to this equation?
[itex]y'' +\frac{b'}{b} y' - \frac{a^2}{b^2}y=0[/itex] where [itex]a[/itex] is a constant |
| Nov13-12, 05:02 PM | #2 |
I assume that b is a constant as well. That's a pretty standard homogeneous linear equation; just use the standard methods (can you write out its characteristic equation?).
| Nov13-12, 05:07 PM | #3 |
No, [itex]b[/itex] is a function, if it were a constant its derivative would be zero and the term with [itex]y'[/itex] would disappear
| Nov13-12, 07:34 PM | #4 |
Recognitions:
You can obtain a lot of solutions by setting b(x) = Axn and solving for y. That won't give you a general solution though.
| Nov14-12, 04:26 PM | #5 |
rewrite
[itex]by''+b'y'-\frac{a^2}{b}y=0[/itex] to the standard form: [itex]z''=-c^2(t)z[/itex], with [itex]c(t)=-\frac{2a + b'(t)}{2b}[/itex] the general solution of the transformed equation is then [itex]z=Asin(cx)+Bcos(cx)[/itex] Then get the solution of y by transforming back: [itex]y=z e^{\int{\frac{b'}{2b}dx}} = z\frac{b'}{2b}[/itex] [itex]y=(A\sin(cx)+B\cos(cx))\frac{b'}{2b}[/itex] That's of course, assuming a,b are such that all steps are valid |
| Nov14-12, 10:16 PM | #6 |
Recognitions:
| Nov15-12, 01:53 PM | #7 |
Oops, you're right, I was thinking too simple! The transformation to standard form does not lead to an expression that can be easily solved by a ricatti equation.
Actually, maple gave the following: [itex]y=A\sinh(\int -\frac{a}{b(x)}dx) + B\cosh(\int -\frac{a}{b(x)}dx)[/itex] hope this helps a bit... |
| Nov15-12, 03:02 PM | #8 |
That suggests the substitution
[itex] t =∫(a/b(x)) dx [/itex] which works wonders :). |
| New Reply |
| Thread Tools | |
Similar Threads for: Sugestions to solve this equation
| Thread | Forum | Replies | ||
| How to solve this partial differential equation which is a Laplace equation | Differential Equations | 3 | ||
| How do I solve this equation? | Calculus | 3 | ||
| solve this equation please | Calculus & Beyond Homework | 2 | ||
| How to solve this equation | Introductory Physics Homework | 8 | ||
